Using Demos
I downloaded a demo on this site http://sleepapneaworld DOT com/
I can nlo longer see my posts and there are tons of new categories. What is the best way to work with a demo? Do I delete all of your posts? How do I edit the categories that you have set up in the demo?
Those would be the demo categories and posts that were imported when installing the demo. You can edit the homepage with the tagDiv composer and configure the blocks and grids to display your own posts from our own categories.
Check the block settings guide I provided in your other topic, as well as the tagDiv composer guide
– https://forum.tagdiv.com/tagdiv-composer-tutorial/
Then you can delete the dummy categories and posts, there will be no need for them.
Let us know if you have further questions, we will help you as best we can.
Thanks this was helpful.
How do I edit the top of the screen.
1) The logo for newspaper 8
2) The ad for newspaper 8 and below that the menu categories:
3) NEWS, FASHION, GADGETS, LIFESTYLE, VIDEO, HOMEPAGES
Are these also updated in tagDiv composer?
Glad it has been helpful. The logo in the header or footer will have to be set in the theme panel
– https://forum.tagdiv.com/logo-favicon/
There are multiple header styles available
– https://forum.tagdiv.com/header-styles/
In the theme panel you can also find the Ads section, that is where you can add/remove the ads which will appear in the website
– https://www.screencast.com/t/TzpHFYOjr
If I missed or misunderstood something please correct me.
