VERY confused on using MOVBLIE THEME.. Need help plz.
Hi there, I have installed Newspaper X and activated the AMP and Mobile Theme plugins.
Also, for my theme I have installed a demo, and customized its elements myself to make it look how I want it to look.
From my understanding, when I use mobile theme, it should show ONLY on mobile. However something weird is happening. I loads with desktop view on desktop, which is good … UNTIL I load it on mobile, it would show me the mobile theme on mobile, and then if I refresh the browser on PC it will also show the MOBILE theme on desktop !!
I don’t know, it should be very simple / mobile theme shows for mobile and desktop stays the same, it doesn’t do that for me. ALSO, I wanna be able to load the mobile theme for the website as a whole, including the home page, not only posts.
Looking forward to reply with your help as soon as possible plz.
HELOOOO ???
Please note that our support hours are from Monday – Friday: 8:00 AM – 17:00 PM GMT+2,
also note that we take in order of time the topics ( time when was post the question ) and if you post/replay again in your topic the time will change and will be move to recent question, therefore the answer will be delay.
If you are using the mobile theme plugin that provide you a better speed then responsive version of theme, but in order to achieve that speed you’ll need to create a new content for pages because in the most of cases those were made with builders ( tagDiv Composer, WPBakery ) and you need to use only the mobile editor ( you need to set the content for pages in mobile editor and this content will be display on mobile theme)
-> https://i.imgur.com/9d0UWLT.png
Also you can show the responsive version on mobile theme -> https://i.imgur.com/m0bVB5T.png you can check more details about mobile theme in our documentation -> https://tagdiv.com/mobile-theme-get-mobile-ready-with-newsmag-theme/ or if you want to have the responsive version only, you can use the amp option from mobile theme -> https://i.imgur.com/oofST3D.png (to use the mobile theme template on amp) or you can disable the plugin.
Hope this will help you!
Not clear to me //
I need a better explanation please, other wise this theme is useless to me.
1. I downloaded and activated both AMP and MOBILE THEME
2. I don’t understand what’s going on, THE MOBILE VERSION IS SHOWING ON DESKTOP !!!
WHY ?
Nevermind,
I fixed the problem .. it had to do with the caching plugin
you instructions for using “WP Super Cache” causes this problem btw.
I deleted it and used a different Cache plugin and now the issue is solved !!
I have also problem with mobile theme. Which Cache are you using? Did you have problem showing images on mobile theme?
I just checked my install with WP Super Cache (I’m using only this cache plugin) with the settings from our guide and for me is working normal -> https://i.imgur.com/FF7EHoK.png
