Trying too activate Visual Composer but having problems.
I deactivated WPBakery and tried to upload the plugins but get the following message:
Installing Plugin from uploaded file: themeforest-5489609-newspaper.zip
Unpacking the package…
Installing the plugin…
The package could not be installed. No valid plugins were found.
Plugin install failed.
HELP…!!!
Hello dirtymedia,
The visual composer activation message appears on all sites that use visual composer, not matter the theme or domain. In our case, you must ignore this message as the Visual Composer does not require activation when it’s provided in the theme package. The plugin authors cannot verify this though so they could not remove the message to this particular case. Please read this guide: https://forum.tagdiv.com/how-to-update-visual-composer-plugin/
All the theme installing should have to be done via FTP because this is the surest and safe method in this regard. For more information about this, please consult here -> https://forum.tagdiv.com/install-via-ftp/
The theme has installed fine just not this plugin?
I’ve tried to install the js_composer.zip but again this fails???
see below:
Installing Plugin from uploaded file: js_composer.zip
Destination folder already exists. /customers/4/4/e/ebikemag.co.uk/httpd.www/wp-content/plugins/js_composer/
Is it worth trying the Tagdiv Composer instead of VC?
I need to be working on this website this week (and it looks like you’ve a National holiday!) so a quick reply would be appreciated!
