Want documantation PDF for theme and help for below issue
Dear Team
1) I need a pdf documentation file so I can read every features how they works. For now I have not received it even when I have downloaded complete folder including license key. Please share that.
2) Urgent Issue to be resolved:
I have removed signin/signup element from home page but still in source code we can see some texts like ‘sign in’, ‘forget password’, ‘your username’, ‘your password’. How to remove it permanently from all pages and posts.
Site dont need public registration.
3) I have enabled ajax view count but view numbers on post are not reflecting. Here they have also mentioned “This feature is best used if you have a caching plugin active.” So do I need to install any plugin? Send link if Yes. Or if I dont need plugin then please share solution.
Hi sproutnepal,
1. Our documentation is online, it can be found in these these links:
-> https://forum.tagdiv.com/newspaper-theme-documentation/
-> https://tagdiv.com/category/documentation/
2. If you are using a cloud header or a PRO Demo, you can edit with tagDiv Composer the homepage and remove the login element using the right click https://i.imgur.com/acOqrXR.png -> https://i.imgur.com/678Y1Wk.png and make sure that the option from theme panel is disable -> https://i.imgur.com/fRIb2xO.png this will remove the code for login, but if you are using a standard/default header style, this will be only hide.
3. The ajax view count is needed only if you are using some cache plugins, in order that the counter to work, this need to be enable -> https://i.imgur.com/nzf6qZy.png also if you are using a single post template from tagDiv Cloud Library, you can add the element using tagDiv Composer -> https://i.imgur.com/Vpv3uIe.png -> https://i.imgur.com/AQ5lloh.png
Dear Calin
1st and 3rd points are done. Thanks for that.
Regarding 2nd issue, please see screenshots of post, home page source code.
Home page source code : https://imgur.com/a/5hCQsC7
Post’s source code https://imgur.com/a/cFlI9qT
I have already deleted signin element from header and also disabled the same from theme panel. https://imgur.com/3JZbxVq but still those text are in source code. These text were triggered by copyscape.org for duplicacy of content. See pink colored text https://imgur.com/xpTCPsz
I am using header template – https://imgur.com/jOW7JXA please suggest if said issue have any connection with this
My website www sproutnepal com
One more thing if anyone can help me.
I am using theme https://demo.tagdiv.com/newspaper_gossip_pro/
And I want 1st block to be look like below theme. For that I have managed to add 1st block template but the concern is all posts inside the block are getting updated together. This was not with the gossip theme, there in 1st block I am able to update any post separately. Is the same possible with below theme’s 1st block?
https://demo.tagdiv.com/newspaper_medicine/
One more issue when i check my browser in mobile version then “Gossip” default theme name/logo is coming. Why? https://imgur.com/a/ueOxqy8
I have added mobile logo through theme panel. Please help on all matters urgently.
The responsive logo need to be change using tagDiv Composer -> https://i.imgur.com/rnCB9b3.png also is look that the login is coming from mobile menu, from these files -> https://i.imgur.com/j6cUNKy.png and -> https://i.imgur.com/gKE4RTZ.png removeing the code from there should solve the problem.
