Want to find title and body
Hello I want to find the title tags and the column tags please tell as my ad codes only work through direct implementation I can find the tags please refer the image and the demo I am using is pulses pro and I want to insert the ads on footer and below and under the post please also specify where in the theme editor I can go and find the tags so that I can place ad codes
REFER IMAGE: https://imgur.com/lXiOpAF
again I say the ads only run on direct impletion on theme editor so I want to know the locations to paste ad code on below the footer after the post and under the post and also header please help me as soon as possible
So you would like to enter an ad code in the header file and in the footer file? What are the exact requirements for the ads? Maybe the theme panel header and footer code can be used instead https://prnt.sc/ubgh2l
If they are required to be entered directly in the files, that depends. Are you using the standard pack plugin or not.
If you use the standard pack plugin, the header and footer files that are used are in it
https://prnt.sc/ubgip4
If you are not using the standard pack plugin, the header and footer files that are used are in the composer plugin https://prnt.sc/ubgjfk
Hello simion yes i want to implement the code in header.php but in which line can i implement so that i can see the ad below logo and the main menu of my website https://healplug.com
And also on footer.php
Ki dly waiting for your reply
So that is the code that actually displays the ads? What kind of ads are you using exactly that have to be entered in the theme files directly in order to be displayed?
The theme provides ad spots and ad boxes for displaying ads https://prnt.sc/uctomi https://forum.tagdiv.com/custom-ad-spots/ No need to enter them in the theme files and loose them after a theme update.
So depending on the header and footer template you use, ads can be displayed in them, without having to enter the actual ad code in the header and footer theme files.
If you use predefined header/footer templates enter the ads in the theme panel ads panel. If you use cloud templates, enter the ad codes in ad boxes, inside the templates
https://forum.tagdiv.com/header-styles/
https://forum.tagdiv.com/footer-templates/
Let me know if you need help. I tried to view the website, it seems to be offline at the moment from what I can see https://prnt.sc/uctrdr
