Want to fix these issues related to header and post
I want to fix some stuff which are described in the video
– Need to fix the slow loading of the header menu
– Alignment or level of posts.
Please edit with tagDiv Composer, select that menu and verify if you have this option “Drop menu items in More” checked, please unchecked it https://i.imgur.com/pbbUXwW.png
The blocks are not aligned because the length of the titles differs.
You can change the excerpt to letters and in this way is possible to achieve what you want -> https://forum.tagdiv.com/excerpts-introduction/
Thanks for the help. Also I want to know creating Mobile themes of the below mentioned templates will create any speed issues or slow down the HTML page?
Also I want to know how would I make my website a boxed type instead of Full Width???
You can use mobile page/templates, but for page speed please check this topic -> https://forum.tagdiv.com/topic/slow-my-webiste/
If you want to make the website boxed, you need to have set a background image/color from Theme Panel -> Background => https://i.imgur.com/i2qlhzX.png and Theme Panel -> Theme Colors => https://i.imgur.com/h808nlK.png and enable the option to make the background boxed layout. Select the row on the header and footer and set the option for “Row stretch” on Default => https://www.screencast.com/t/I7lDMXJjiwZ -> https://www.screencast.com/t/O8cc7n4ZzIc
Also, How would I reduce this? Is this caused because of the theme? Because am not using any useless plugins
Please let me know what tool you used for tests and the link to your website.
A solution to your problem would be to add more text to the page using the element “column text” or in the “text with title” => https://www.screencast.com/t/NsyYy3VHXQd or delete from the blocks used on the page -> https://forum.tagdiv.com/topic/seo-problem-aioseo-and-tagdiv-composer/
Hiding some elements on mobile and some on desktop view destroyed my homepage. Any solution?
Website link
All the blocks on the page are made using HTML.
So, you need to have more text on the page, as I said above.
Please check the website again. Now I’ve set more texts on the homepage.
Image Check Please
You need to add text, not to display the title of posts, because are also, HTML elements -> https://www.thewebinaut.com/blog/pages-have-a-low-text-html-ratio
And what about images Size? Why HTML document is so high. Even due to using Ewww optimizer. Do you think the theme is causing this? If not, what should I do?
Hello @iamratnesh!
Make sure your images don’t have bigger size in Kb. You can use some free websites where you can optimize the images, then upload on your Media Library.
