Hi. I was running the Newspaper template perfectly. Now suddenly it stoped working.
I´m hosting it in AWS this is the link http://52.48.50.64/
Can it be something in the template? I didn´t touched anything for days.
Unfortunately i cannot access your site so I cannot say for sure what is wrong. Please disable all plugins excepot visual composer, clear cache and reset cdn files if you use it. Also make sure you update your theme by following this guide: https://forum.tagdiv.com/how-to-update-the-theme-2/ and https://forum.tagdiv.com/how-to-update-visual-composer-plugin/
