I have few common page speed issues on my website. I am using w3total cache plugin and tag-speed-booster plugin but still google page speed tool shows few problems like Leverage browser caching, Eliminate render-blocking JavaScript and CSS in above-the-fold content, Minify CSS, Enable compression, Minify JavaScript and Minify HTML.
So kindly guide me how to fix this issues with proper code.
Hello Aakash,
First of all, please notice that the W3TotalCache plugin is not tested with our theme and it seems to cause a lot of problems through the theme, sorry! You should use the WP Super Cache which is our recommended caching plugin.
Please notice that the speed of your website depends on how well your site is optimized. Notice that is not a simple task and if you do not have any experience in this regard you will do not bring good results for the theme. Also, notice that we have a speed optimization tutorial but this is addressed only to advanced users. So, if you follow the steps which are presented in this tutorial here -> https://forum.tagdiv.com/how-to-make-the-site-faster/ you can increase the page speed loading and if you are not aware of the steps in this regard, please consider hiring a freelancer/developer to help you because the speed optimization services are not covered by our support policy, as you can read here -> https://forum.tagdiv.com/support-policy-2/ Check our documentation here -> https://forum.tagdiv.com/requirements-for-newspaper/ regarding on dedicated server to fit to our requirements. For an example, you should check our demo preview because this website is optimized.
