Widgets problem
Sir,
I have a creating a same widget on my website but not a showing of this block on my Tagdiv Composer…
https://imgur.com/xRa3LT5
please help me
That is an ad, most probably an adsense, if you want to set the ad in sidebar too, then you need to check first if you are using a cloud template or a standard template for posts. If is a cloud template the ad need to be set with tagDiv Composer in ad box element, if is a standard template, the code can be set in a sidebar widget that is assigned to that post.
sorry calin, sir
I am not a understand please provide full detail
If I understand correctly you want to set some ads in your sidebar, this can be done on pages and cloud templates using tagDiv Composer and adding and element name ad box, using the ad box element and you can use the ads from theme panel -> https://i.imgur.com/NmqJa0r.png or the image ads-> https://i.imgur.com/LXheXDT.png or you can set the code in custom ad -> https://i.imgur.com/Ef7dFgp.png
Using ads -> https://i.imgur.com/xEd4pMB.png -> https://forum.tagdiv.com/ads-adsense-overview/
If this is not what you mean, please provide some more details.
Sir, I do not have to do this, I have to create a widget, simple for the popular post I have shown you the photo when this widget is in gadget theme but I am using the default theme so I do not see it.
How to use this block in the website widget.
Check This image please:-
https://imgur.com/9uFKL1q
That is the “Recent Posts” element from widgets. That widgets in gadget demo has an extra class that make it to look like that also the gadget demo has an extra class in -> https://i.imgur.com/AR4IZx5.png these are working only when you have install that version or using custom css.
