WP Editor does not work! (Error 404)
I’m having difficulties with the “wp editor”, whenever I try to edit from “Text with title”
The window only shows that it is loading and does not display the editor.
The Google Chrome message is:
wpeditor.php:1 Failed to load resource: the server responded with a status of 404 (Not Found)
All plugins are disabled.
This problem seems pretty common, you could fix it.
I am waiting for the answer.
Hello @indac!
This problem it can be caused if something interfere there when the WP Editor saves the content you added and the process can not be completed. Please check the steps from here: https://forum.tagdiv.com/topic/unable-to-edit-text-with-title/ and also other possible issue as here: https://forum.tagdiv.com/topic/403-error-on-tagdiv-composer-when-trying-to-use-wp-editor-wpedito-php/
Check this guide too: https://forum.tagdiv.com/general-options-may-interfere-newspaper-theme/
Let me know the results!
hello betina
I checked the items on the list in the post you sent me. But it did not work! Error 404 continues.
I use WHM/Cpanel hosting.
Any idea?
hello betina
WP EDITOR is now working!!!
I installed PHP version 7.4 on my server and the error is gone. Before I was using version 7.3.
Thanks, resolved.
Hello @indac!
I’m glad you have managed to solve the issue.
Let me know if you need further assistance.
Have a nice day!
I have PHP 7.4.27 but the error remain.
Any other solution???
Hello @itgrcapitallink!
If you checked all the possible issues from above and the problem is still there, then we can take a look and see what happened there. Please contact us via email at contact@tagdiv.com and provide the following:
– admin url and credentials
– cPanel url and credentials
Our team will take a look!
Everything works right now!
I de activate and activate again all the plugins.
