WP Editor does not work
When I click on the “Edit Content” button a window called “WP Editor” opens but I can’t edit the content (hourglass permanently). This occurs for the following shortcodes: Text with title, Column text.
Best regards
As a first suggestion you could check the theme requirements guide carefully
If needed contact your hosting provider to increase the allocated resources, or activate the needed PHP extensions.
Then try again to see if the issue is solved.
In case there is no need for modifications in that matter, in some cases the solutions from these topics worked for various composer problems, you could give them a try if possible
– https://forum.tagdiv.com/topic/gray-page-tagdiv/
– https://forum.tagdiv.com/topic/javascript-error-td-composer-wont-load/
Let us know what you find.
It was a third-party plugin that created the problem.
Best regards
