Sorry but for me now is useless Cloud Template, so i think i won’t upgrade it anymore because of lack of basic function.
Ok, but when you gonna add a tag description shortcode?
I would like to use Cloud Template but is useless because there is no option to add tag description shortcode. Is there a way to add load more button to tag php template?
Yes, im using a your demo which is prepared for this
and we are at the problem no. 1
Better π but there is a little margin at left.. π
safari: https://imgur.com/HMHVwGG
there is a still empty space but smaller
How to fix it this at mobile? π
Great support as always π work thanks
here is a our test version: https://bergside.pl
So the theme is not ready for full translation.
Sorry but it do not work from child theme folder and i don’t want to edit this file every time of update
Closed!
Can you tell me how can i also remove a category name from breadcrumb of post?
https://porady.org/bol-kregoslupa-ledzwiowego-jak-sobie-z-nim-poradzic
But you did this here so you can help me:
https://porady.org/jazda-wozkiem-widlowym-bez-tajemnic/3
So this is a bug and should be fixes π
Yes and doesn’t work π it is a really weird bug, look at this Simion:
My child theme folder, and original folder is without change!
Unfortunately there is no option there to remove /page/ from pagination page π i though that you, great dev, can help me with this quickly, i spent many hours for looking for that in the internet and no solution works…
So please add it soon π
But there is no box like at tag page π
