All in ONE SEO plugin is not compatible with Tagdiv’s Opt-in Builder
Please fix this compatibility issue in the next update, because Yoast SEO does not support .webp image but All in ONE SEO does.
So many of us prefer All in ONE SEO to traditional Yoast SEO
Problem with Locker (Op-in builder) – Please fix it ASAP
Problem1: Email Locker does not work with CDN/Cache
Result: Same email locker present even after users provide their emails – does not unlock content even after users provide email.
Example URL: https://www.thechinexpress.com/us-senator-young-myanmar-ralkap-hi-a-tuhmi-theipar-zunter-caan-acu-cang/
Problem2: Subscription Locker works halfway only. After user clicks ‘Subscribe Button’ it redirects them to Plan modal and everything works, then the problem starts.
Result: CND caches the content and its available for free for everyone, making Subscription Locker useless.
Example URL: https://www.thechinexpress.com/thawngtha-chinmi-caah-oxygen-sehzung-kan-sak-lai/
I reach out to BunnyCDN Support and below is what they suggest.
I suspect this may be an issue with the paywall plugin you’re using, it might be worth reaching out to them to see if they can see what is going on here as it sounds like they’re re-using the same URLs here which may be causing the issue.
If they can give us paths to exclude from the CDN, we can look to get this setup for you.
Best Regards,
Harry
bunny.net
https://bunny.net
This reply was modified 4 years by
Lian. Reason: wrong key words
This problem remains unsolved with the latest update
Single Post Bg Featured Image cached when used tagDiv CSS Analyzer.
Result: Display the same image on all articles.
Please fix this ASAP.
Please add this feature in the next update. We need it.
Please add this feature in the next update. We all need it.
Hi Calin, I can’t find the directory. Could you please update?
Please share the solution. I also want to disable woff. Thank you
Update: I already resolved the problem
Now it’s saying error is on line 79 instead of 81.
Mobile theme footer logo error “Undefined variable: logo image width and height”. Please see screenshot here
This is your code on the mentioned line 81. Please give me a fixed code.
Thank you
Go to Them Panel > Custom Code > Custom CSS
and put this code
.single blockquote.td_quote, .single blockquote.wp-block-quote {
margin: 0 0 29px 0;
border-left: 3px solid #4db2ec;
padding: 15px 23px 16px 23px;
position: relative;
top: 6px;
clear: both;
.single blockquote.td_quote p, .single blockquote.wp-block-quote p{
font-family: ‘Open Sans’, arial, sans-serif;
color: #4c9d3a;
text-align: left;
font-size: 13px;
line-height: 21px;
margin: 0;
text-transform: none;
Hi Vlad,
I now changed my fonts to default, just like your screenshot. But three types of fontAwesome are still loaded [Screenshot]
I want to completely disable fontAwesome. Could you please give some code to do it?
Thanks in advance
I want to disable theses fonts;
1. newspaper-icons.woff?1
2. newspaper.woff?19
3. fontawesome-webfont.woff2?v=4.7.0
They slow down my website by 1 second Screenshot
I thought they were used for icons, so I do not use any icon including social icons but still the same.
Please also have a look at my website if there is anything using these fonts, and suggest how to disable them.
Thank you very in advance
I also want to change link color to my liking.
I also face serious problems.
So I delete official AMP plugin and also disabled it in theme panel.
This new move is extremely bad and its useless. It creates more problems than benefiting users.
I miss using TagDiv AMP plugin, it was very good.
Me too. All posts get AMP Error. Here is screenshot https://prnt.sc/mvclja
Is there a solution?
I have other issues again;
1. Featured image is not showing for AMP post (mydomain.com/post/amp/) on Google AMP tester’s Search Result Preview and also on the real search result – everything was fine when I switched to AMPforWP plugin, but I prefer tagDiv AMP design (ads look better than those of Ads for AMP by AMPforWP) if possible.
2. I use tagDive Composer’s Grid 3 on the first row of my homepage. Its perfect on desktop but on mobile device. Only 2 articles out of 4 are visible, and I need to swipe left to see the remaining 2. Please check thechinexpress.com on mobile device and you’ll know what I am trying to say. I wish I could make everything showing perfectly on mobile device without having to do something to make it. Its fine if I use tagDive mobile theme plugin, but it drops my website speed a lot (also need to defer parsing of js a lot, etc.) and adsense page-level ads does not work on it, which is important 😉
my site runs on PHP 7.1. Its hosted on SiteGround’s GoGeek Plan (shared).
