AMP + Mobile Displaying Problem
Hello, i do have a problem with my website using AMP + Mobile theme
as you can see this is how it looks on mobile:
https://i.imgur.com/h2yGi8z.png
also, i noticed that i don’t have the option of AMP on the left menu bar of WordPress as it is shown on your tutorial here:
https://tagdiv.com/wp-content/uploads/2018/02/amp_settings_2.png
I spend a few days trying to solve it but nothing, how i can fix it, please!
Ps: you can check the website, https://www.techonnect.com/
Thank you
Also, i get this on posts on mobile:
https://i.imgur.com/uGxYVSr.png
Update: just to give you an insight, i deactivate all the plugins, then i start activating them one by one to localize the problem, I’ve noticed that when i deactivate tagDiv Mobile Theme plugin, amp website version works totally fine on mobile regardless the settings whether it is AMP, Mobile, or Mobile + AMP, but once i activated it i notice the same problem but only on the home page, not the others!!
Another update: Once i deactivate tagDiv Composer the error gone, yet i lose all the design so probably the error on class “td_style” as it is mentioned on the front page as Fatal Error, please i need a quick solution guys!
TagDiv Composer is the core of the theme -> https://tagdiv.com/tagdiv-composer-page-builder-basics/
Please use the amp plugin with the mobile theme plugin as in our documentations from here :
-> https://forum.tagdiv.com/the-mobile-theme/
-> https://forum.tagdiv.com/tagdiv-amp-plugin-tutorial/
Use one of these options for amp -> https://i.imgur.com/xM75y2R.png in this way the invalid markups will be solved and the amp will work better.
Also you can use the settings from theme panel, these will be apply for amp and mobile theme too -> https://i.imgur.com/6QXJvFR.png -> https://i.imgur.com/mi0qdQf.png
Let me know if the problem persist!
Thank you for your detailed replay, well, i did all what you’ve explained to me, and the page loaded correctly, however, when i tried to use the “Mobile + AMP” option the problem will appear! Also, when i try to analyze the website to know whether it is using AMP or no using this tool “https://search.google.com/test/amp” it shows that the main page isn’t AMP, however, it uses this URL https://www.techonnect.com/?amp
which shows even more errors -> https://i.imgur.com/ySbrCLZ.png
Also, as you can see i can’t change the menu background nor the colors whatever colors i pick on the mobile theme setting -> https://imgur.com/a/cFbO4wl
HELP!
Please send us an email at contact@tagdiv.com and provide admin login, as well as cPanel. We will take a look. Include a link to this topic in the email.
This can be change from theme panel -> https://i.imgur.com/S5X86RA.png -> https://i.imgur.com/hLZjDJa.png or if you are using the mobile theme plugin you can change it from here -> https://i.imgur.com/Xb4c3Pu.png -> https://i.imgur.com/NqKHTQW.png
Background introduction -> https://forum.tagdiv.com/background-introduction/
