Please provide the link to your website.
Also, please check our documentation about amp and mobile theme -> https://forum.tagdiv.com/mobile-theme-introduction/ -> https://forum.tagdiv.com/tagdiv-amp-plugin-tutorial/ -> https://forum.tagdiv.com/the-mobile-theme/
Link: https://NoticiasLx.pt
the article: https://noticiaslx.pt/2023/02/02/loures-apresentacao-publica-metro-ligeiro-palacio-dos-marqueses-parque-da-cidade/
This reply was modified 3 years by
AntonioT.
For AMP, the settings are from Theme Panel -> Mobile Theme, so if you hide the featured image from Mobile Theme, you hide it also for AMP.
Please check this topic where I explained each mobile version -> https://forum.tagdiv.com/topic/mobile-version-not-working-properly-2/ and choose your mobile version.
My problem is not the Image.
[original question]
When I use an “Audio Article” with link to the file in “Feature Audio” it shows the audio control in Desktop but in AMP I must use an “AUDIO BLOCK” to have an audio control.
So in Desktop my article have two audio controls.
AntonioT.
I have removed the “hide image” in Mobile Theme but,
As you may confirm, in Mobile, it shows the image and the audio control now
but not in AMP.
The article/Audio Link: https://noticiaslx.pt/2023/02/02/loures-apresentacao-publica-metro-ligeiro-palacio-dos-marqueses-parque-da-cidade/
AntonioT.
For the audio block, you can add an extra class https://i.imgur.com/yikEH7I.png, so you can do a custom code to hide it for the desktop and display only for the amp, set the code here https://i.imgur.com/caVLVwm.png
