Having problems activating td composer
Hi, mi website crashed when i published a post. I can´t reach admin page but youn navigate in the webiste.
I disable all plugins and work. Activating one by one, when i activate TD Composer it does not work any more.
With TD composer desactivates, the newspaper panel in the admin section does not have the system status section.
If you use default templates, please make sure you have the Standard Pack plugin installed and active.
Please make sure you have the latest version of the theme and plugins(11.2).
Please check if this code is missing from your htaccess file: https://www.screencast.com/t/iN0R93dD3p from our requirements, make sure you have all the requirements as you can see here: https://forum.tagdiv.com/requirements-for-newspaper/
We have a guide for how to investigate this problem and fix it: https://forum.tagdiv.com/tagdiv-composer-not-working/
Let me know the results!
