Help with errors customising website
Please help me with these 3 problems i am facing. Much appreciated
Watch video here:
https://drive.google.com/file/d/1qDCmPriGOIvAKuuKDU2X2_eK4pthpl3l/view?usp=drivesdk
1. I think that you are using header style 6 or multipurpose style 3.
Now the css code that you have in Theme panel is not for the menu background, this is set from theme panel> theme colors -> https://www.screencast.com/t/FPN29npU also now you can use cloud headers from tagDiv Cloud library and you can edit them using the theme builder, tagDiv Composer.
2. So in order to have the grid stretch on full width you’ll need to use the tagDiv Composer, edit the page and set a Big Grid Full -> https://i.imgur.com/1wvFEnc.jpg
Big Grid Flex Settings -> https://forum.tagdiv.com/big-grid-flex-settings/
Block settings tutorial -> https://forum.tagdiv.com/block-settings-tutorial/
3. The Visual composer that you are using is an old version, now the update version is WPBakery, but we recommend to use it with our theme only if you do not use cloud templates ( using cloud templates with WPBakery can create conflicts).
Also you can check more in our documentation from here(new documentation) -> https://tagdiv.com/category/documentation/ and from here( old documentation ) -> https://forum.tagdiv.com/newspaper-theme-documentation/
Hope this will help you!
1. I changed it from style 6 to style 3 multipurpose but still see the black load
Here are my custom css. I believe one or some of the custom css are causing this
@media (max-width: 767px){
.td-scroll-up {
display: block!important;
.td-post-category, .td-entry-category, .td-big-grid-meta .td-post-category, .td-module-comments{
background-color:#a00000;
.td-instagram-main{
border-bottom:9px solid #d93a00;
.td-scroll-up{
background-color: rgba(68,68,68,0.45)!important;
.td-main-content-wrap {
padding-top:0;
.td-module-comments a{
background-color:#cecece!important;
.mycustomclass span{
background-color:#222222!important;
.mycustomclass{
border-color:#222222!important;
.td-icon-star, .td-icon-star-half, .td-icon-star-empty{
color:#d93a00;
.td_module_6 .entry-title{
font-weight: 500!important;
.widget_display_topics{
margin-bottom: 23px!important;
.widget_display_forums{
margin-bottom: -36px!important;
@media(max-width: 767px){
.td-footer-instagram-container .td-footer-instagram-title .td-footer-instagram-user-link{
display:initial!important;
.td-search-wrap-mob .td-search-input span{
font-size: 30px!important;
.td_block_big_grid_12 .td-big-grid-wrapper .td-big-grid-post:last-child .td-module-thumb {
margin-left: 0px!important;
2. I have changed it to big grid full but still not showing full width. Help?
3. If the new one is called WPBakery, am I still not supposed to have a copy of it since I bought it with the theme? Or I have to pay for it?
4.Won’t using TD Composer and WP Bakey cause conflicts? I used to only use visual composer and now youve asked me to use tp composer to change big grid settings
1. Did you try the theme panel settings ?
Because there is no css for header.
2. Did you try to stretch the row with tagDiv Composer -> https://i.imgur.com/6a63GpG.jpg
3. That plugin is not bought is provide by the Newspaper team, the WPBakery ( old Visual Composer ) is a bundled one -> https://help.market.envato.com/hc/en-us/articles/213762463-Bundled-Plugins if you download the latest version of Newspaper theme from your themeforest account then you’ll find the plugin inside the packages, this will have the old name js-composer.
4. Now the theme builder is tagDiv Composer, using the tagDIv Composer and visual composer on standard pack should work normal, only if you activate the tagDiv Cloud Library and use cloud templates, this theme extension was build for tagDiv Composer and is not compatible with visual composer, also we do not recommend to use on the same page more then one builder.
1. Yes I tried it but it did not work.
2. I also tried this but it does not work
3. I am aware it is bundled however it does not work like it used to. When I go on a page to edit and scroll down to the Visual Composer section, it does not load anything therefore I cannot edit. A couple years ago it used to work perfectly fine. The only thing that seems to work now is TagDiv composer, Classic editor and Block editor.
4. Ok thank you. Which composer would you say overall is best for this theme? TadDiv or Visual?
1-2-3. If you want you can send us an email at contact@tagdiv.com and provide admin login. We will take a look. Include a link to this topic in the email.
4. The theme build its own builder, tagDiv Composer, all features are related to this builder, therefore we recommend to use tagDiv Composer.
I have sent it over, thank you
