how can i setting in wordpress for RTL, and how can i use flex blocks
Hi few days ago i contact you for support via coment section via newspaper sale page but your one of team said me contact with forum suport page so i m sending you all details
Question 4 days agon i asked that question
Hi how are you all I want to know that how can i make text from left to right side i made website in urdu language and its start from right side as Arabic language start Here is website which i m taking about fbwebtv.com
Reply than received below reply
The theme doesn’t support RTL. It works with with the RTL languages but it will have to be modified to be completely mirrored. If you want you can try by setting in WordPress and rtl language and use flex blocks, these can be edited with tagDiv Composer. If you need further assistance our support team will be happy to help with any requests on our official support forum at https://forum.tagdiv.com/forum/newspaper/
question i asked again question
how can i setting in wordpress for RTL, and how can i use flex bloks please let me know and send me complete details my client just want to start text from right side not in right side you an check website fbwebtv.com and advice me what do i do
Reply received Below reply
Sure thing, but the comments section here is not a support platform so we cannot provide any details here. Please open a new topic on our support forum at https://forum.tagdiv.com/forum/newspaper/
Thank you! Bogdan B
Other questions
Hi, please below screenshot
1 http://prntscr.com/q49tcf
2 http://prntscr.com/q49u0h
3 http://prntscr.com/q49uvv
and when i go to cloud template and click on add new so i see this error please see screenshot http://prntscr.com/q60z7t
please answer my all question so than i can fix that issue my client is continuously contacting with me to fix that issues if you guys want wordpress login details of fbwebtv.com so i can provide you guys
waiting for your earliest response sir
so now please tell me all my above questions and give me complete details so i can fix that issues
Sorry but our themes are not compatible with the RTL direction. IF you need a RTL theme, you will have to choose a different theme that can provide this functionality. We will be able to provide a refund if you make a request here:https://themeforest.net/refund_requests/new
Please check our flex block -> https://forum.tagdiv.com/flex-block-settings-guide/
The most text/titles from classic demos can be change using the Translation from theme panel -> https://i.imgur.com/YGOfrVY.png -> https://i.imgur.com/1lefHDT.png -> https://i.imgur.com/UtxcKBl.png also the footer can be change from theme panel, or you can use a page as footer page.
Usually the “Invalid reply from server endpoint error” is caused by insufficient WP_Memory_limit
https://prnt.sc/q49uvv can be achieve with tagDiv cloud template -> https://i.imgur.com/PpkP2ZG.png
Hope this will help!
When i m sharing any post link on facebook its showing like this please check screenshot
http://prntscr.com/q9olaj
and when i m copy and past any post url so its showing like thatplease check screenshot
http://prntscr.com/q9om51
post should be show like this on whatsapp please check screenshot http://prntscr.com/q9on3q
All of your screenshot which gave me in my first question all are not opening please check screenshot http://prntscr.com/q9pcmo
https://i.imgur.com/YGOfrVY.png -> https://i.imgur.com/1lefHDT.png -> https://i.imgur.com/UtxcKBl.png https://i.imgur.com/PpkP2ZG.png
please resent active screenshot links my client is angry with me still issues was not resolve
footer page is not showing here so how can i update please check screenshot http://prntscr.com/q9s1tv
i m also sending you wp website login details so you can check
login url: fbwebtv.com/wp-admin
wp user: newsdjidses
wp pass: Q%9bU%W7p9
please check my all questions and reply all answer again becuase which screenshot you sent me these are all not opening https://prnt.sc/q9pcmo
For sharing posts, you’ll need to make sure that you have og on that posts, we recommend the Yoast SEO plugin to manage sharing on socials, and provide the og data, the theme by itself doesn’t have what is required – https://forum.tagdiv.com/facebook-share/
Also please make sure that you do not have some plugins that can interfere with the sharing option, please deactivate all non theme plugins!
For me the images are working -> https://i.imgur.com/I0Ir7Ak.png -> https://i.imgur.com/r5zZqdX.png
You can set any page as footer page, there is no need to be a specific page.
Dear sir, i m really getting trouble, i have share with you all details of website
but cloud library is not still loading you gave me mostly answer which can be resolve via Cloud library and when i open it and and new template i see this error (Invalid reply from server endpoint) this issue not resolved please fix that issue so than i fix some issues via it
and please answer complete below isuse
please check screenshot https://prnt.sc/q49tcf
i m talking about post page not not only page
how can i edit post via tagdiv composer
you answer me this
and i did not get my answer what i asked
please let me know how can i use tagdiv composer in new and old post
i have given you above website login details please check
please fix cloud template issue its not importing
  • This reply was modified 6 years by Calin.
Also please do not share your private credentials on forum.
Usually the “Invalid reply from server endpoint error” is caused by insufficient WP_Memory_limit, I’ve set it to 256M, now it should work -> https://i.imgur.com/Hjpd1Qk.png
Also please notice that we do not recommend to use WP Bakery with tagDiv Cloud Library, if you want to use cloud templates, please deactivate it.
please check this http://prntscr.com/qci6wv and pleas check this http://prntscr.com/qckja5
how to create any news post in tagdiv composer, i have disable wp backer but still not find a way to create or edit post in tagdiv composer please screenshot http://prntscr.com/qcjq7a
please tell me way that how can i edit old post in tagdiv composer because my client want to start post with right side you…. i tried but i could not find way to ad new post or edit any post via tagdiv composer please let me know thanks please see screenshot http://prntscr.com/qckigo pleae give me must answer that how can i edit any old post in tagdiv composer
and other question how can i start menu from right side
please check screenshot http://prntscr.com/qckgu6
pleas check screenshot http://prntscr.com/qckhd8
pleas check screenshot http://prntscr.com/qckktq
also please check that screenshot http://prntscr.com/qcl2ji
That is because you still have http on your website, there should be all link https, you should be able to fix this using some plugins for ssl -> https://wordpress.org/plugins/really-simple-ssl/
The tagDiv Composer is a builder for pages and templates only, not for post, only for post templates, so if you want you can use it on a single post template from tagDiv Cloud Library.
You can use a cloud header from tagDiv Cloud Library and you can set the search icon and logo in the place you want. -> https://i.imgur.com/rA7fxVB.png
Please notice that you can edit only the single post from tagDiv Cloud Library, this one -> http://prntscr.com/qcl2jiis a standard post style/template -> https://i.imgur.com/Wn7j9RP.png
Let me know the results!
how can i assign any single post from tagDiv Cloud Library to any category please also check screenshot http://prntscr.com/qdkvxr
please check screenshot http://prntscr.com/qdkuty
please check screenshot http://prntscr.com/qdkzcd
please answer me with detail so can complete website work my client
because my client is angry with me that i m delaying his work
Please notice that in tagDiv Cloud Library you can find the templates for the entire theme -> https://i.imgur.com/0V7Dts0.png for categories, you need to use a category cloud template, this is a little different from the single post templates, but it can be edit the same using the tagDiv Composer.
Also please notice that these are only the templates, the posts need to be make in WordPress, using an editor like Gutenberg, from there you can assign the categories to the posts -> https://i.imgur.com/RLY30di.png not from here -> https://prnt.sc/qdkvxr from there you can change the layout.
In this image -> https://prnt.sc/qdkuty you are editing the post title, this is just a place holder to see how will look the posts elements, so there will be set the post title after you assign the single post template to some posts.
Also here -> https://prnt.sc/qdkzcd you edit the single post template ( the layout not the content) in order to change the title , text image you’ll need to edit the post -> https://i.imgur.com/oAVu1zT.png
