Hi there,
I’d like to add a display ad to the top of my articles/posts by default but not sure how.
When viewing on desktop I can see there’s one on the right, so that is fine:
https://drive.google.com/file/d/105acg20Vfc5dY-AgTf39sg3vXCZfWcNY/view?usp=sharing
But when I view articles/posts from mobile there isn’t one at the top, only the bottom:
https://drive.google.com/file/d/19lpBsootVXUUSihFG6mY8kjFVSRYpivL/view?usp=sharing
If someone could advise me on how to achieve this so it’s applied by default and I don’t have to add it manually to each article I write that would be amazing! I think a wide rectangle one (as seen in the first image, header) would be better than a big square one (as seen in the video when I scroll to the bottom).
Thanks in advance!
Hello @jackb149!
In the cloud templates, you can add the ads when you edit the post with TagDiv Composer in the element called ” Single Post Content ” in the tab ADS. Documentation here: https://forum.tagdiv.com/article-ads/
Or you can use the element called “Ad box” from TagDiv Composer, and there you need to add the ads: https://forum.tagdiv.com/ads-adsense-overview/
In order to customize the ads on mobile, this will depend on the mobile version that you use. You can choose from three different options:
1. Responsive version: A responsive version of your website looks similar to the desktop version. TagDiv Composer is used to edit the page. Click on the mobile viewport: https://www.screencast.com/t/XDQJedlggSB. There, you can see your mobile version and edit or adjust the elements to look better.
2. Mobile pages: https://tagdiv.com/newspaper-10-3-7-update-brings-customizable-and-fast-mobile-pages
3. Mobile theme plugin: The Mobile Theme is a performance-optimized theme included in the main Newspaper theme that only loads on mobile devices. It comes with its own templates and designs for pages, posts, categories, etc., so your current templates from the desktop theme will get converted to the mobile theme layout. Please see https://forum.tagdiv.com/the-mobile-theme/ and https://forum.tagdiv.com/mobile-theme-introduction/ for more information.
A full explanation is here: https://www.youtube.com/watch?v=SpGkOnJeNZY
In your example, the last column is the column from the right(desktop). But, we have an option to re-order the columns: https://forum.tagdiv.com/topic/how-to-re-order-the-post-page-on-mobile/
