I need help with the Newspaper 8 theme
Greetings!
I need help with my website africanstar.org, which is using newspaper 8 theme. It does not represent the theme. Please advise
Unfortunately I don’t quite understand what you mean. Some more details would be helpful.
I do not see where and how I download the file for Visual Composer.
WPBakery is always included in the theme package, in the plugins folder
– https://forum.tagdiv.com/whats-included/
– https://www.screencast.com/t/4rHXCpGgL
I bought the newspaper 8 theme over a year ago, and these plugins: TagDiv Composer and tagDiv Multi-Purpose are no where to be found. Please help me activate them. website: http://www.africanstar.org
  • This reply was modified 7 years by Simion C..
The tagDiv composer was introduced in version 8.0, the multi-purpose plugin in version 8.5. Then in version 8.7.5 the multi-purpose plugin was removed as a separate plugin, all it’s features are now included in the tagDiv composer fully.
The latest theme version is 9.1, changelog with new features and modifications here
– https://themeforest.net/item/newspaper/5489609 (bottom of the page)
If you want to install the latest version, simply download the theme package from your themeforest account. This is a guide for updating the theme
– https://forum.tagdiv.com/how-to-update-the-theme-2/
Be sure to review the theme requirements guide, there were some modifications and additions
As a note, please don’t post login information in the forum, the topics are public for all the theme users. I will edit the post and remove them.
