Improve speed of site
What is the most speedy setup in terms of loading time and loading size for the template?
– Cloud library
– Demo install
And which plugins do I need and which of them can be deactivated after setup of template like standard pack and cloud liberary?
As far as I understand … Cloud library is much faster than demo install, because the CSS files are only template specific and also I do not need to install standard pack to use the templates from cloud library? Also can I deactivate cloud library plugin after installing the different templates from the cloud library?
Best regards
If you won’t use default templates, then you don’t need to have Standard Pack plugin installed. Also, cloud library plugin can not be uninstall if you use a cloud template.
If you follow the steps which are presented in this tutorial here: https://tagdiv.com/how-to-increase-page-loading-speed/ you’ll be able to increase the speed of your website.
Also, to increase the page speed you can check these similar topics for more solutions:
– https://forum.tagdiv.com/topic/optimize-script-to-improve-site-speed/
– https://forum.tagdiv.com/topic/a-few-tips-for-newspaper-x-speed-high-cpu-usage-issues/
– https://tagdiv.com/how-to-increase-page-loading-speed/
Please note that page speed is not covered by the support team: https://forum.tagdiv.com/newspaper-theme-support/
Please give it a try and follow the steps which I presented above about page speed.
Also, check our guide from here: https://forum.tagdiv.com/how-to-make-the-site-faster/
Our developers are working to improve the page speed, so we hope in short time we will deliver the improvement in the future updates.
