IN HOME PAGE IMAGES OF MY POST ARE NOT SHOWING
in my home page images are not showing
Please make sure that the thumbs are enable in theme panel -> https://forum.tagdiv.com/theme-thumbs/
Also make sure that you do not have a plugin conflict, please deactivate ALL plugins except tagDiv Composer, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
If there is still a problem, please provide a link to your website where I can check this problem.
Let me know the results!
thanks for your kind replay, we uninstalled the other plugins,
but the issue is not solved
am sending the link http://www.minecampus.com/blog/
The images are not show in the homepage because you do not have set and featured image on your posts, please set theme as i our documentation from here -> https://forum.tagdiv.com/featured-image-or-video/
but in my home page so many areas area going empty.
see the filed under
1) don’t miss
2) life style news
3) house design
even we would like to change the topic headings also.
please refer website http://www.minecampus.com/blog/
If you are referring on these sections -> https://i.imgur.com/uMNAMGt.png in most case set there is set a filter that will not return posts, please check the filter tab on each flex element tab using tagDiv Composer -> https://i.imgur.com/1IHEJRf.png
but TD composer taking a long time to load and am unable to make a change in FLEX BOX
