Ive been asking for help but no one seems to be able to help me!
Simi360 #221975
Mar 8, 2018 at 8:18 pm
Is there a chart that you can provide so i can make sure all photos are correct sizes per section? This is becoming a constant problem.
Please let me know how I can fix this
REPLY
Catalin
Catalin #222101
Mar 9, 2018 at 3:24 pm
Hello Simi360,
You should regenerate the thumbnails using the Force Regenerate and Thumbnails Regenerate plugins. Please check the following documentation from here -> https://forum.tagdiv.com/thumbnails-fix-strange-looking-images-on-blocks/
REPLY
Simi360 #222236
Mar 10, 2018 at 3:40 pm
I also wanted to know if there were specific dimensions for each block? Sometimes they do not show up centered and instead show only part of a picture I would like to make sure that all photos are centered evenly.
REPLY
Edward #222240
Mar 10, 2018 at 4:25 pm
https://forum.tagdiv.com/thumbnails-vs-featured-image-size/
https://forum.tagdiv.com/theme-thumbs/
REPLY
Simi360 #222242
Mar 10, 2018 at 4:37 pm
Also your suggestion did not fix the issue is there anything else we can do to put this into gear
REPLY
Simi360 #222368
Mar 12, 2018 at 7:37 am
Hello is there anyone here to help me?
So the issue was not solved by regenerating the thumbnails. Inspecting the website and the first thumbs issue in the grid, it seems the featured images you use are too small. Example:
– https://www.screencast.com/t/9xKtYxfUz
This module where the post appears has a thumbnails requirement like this
– https://www.screencast.com/t/y1EtZitN
So the original image is simply not big enough to allow the creation of the necessary thumbnails. Use bigger images if possible or a thumbnail upscale plugin, the theme will not stretch the images to fit if they are too small.
As mentioned in that guide our install-able demo uses images around 1068 × 713 px. You can use bigger images, the resulting thumbs will be of higher quality.
Perfect thank you I will give this a try. Please just one last thing and I will leave you guys alone. I have attached a link to an image and there are 3 spots on here which I need help.
1) Weather Widget. I attached API and still does not work, I followed all instructions and still nothing. Is this not working?
2)I have looked everywhere I cannot find where to edit this option.
3) In order for me to remove the placeholders, i had to use CSS. I should have to do that. Is there a way to remove the placeholders that are there?
Thank You
there are two sections which I cannot seem to be able to replace can you please advice me how…
1. I have tried configuring the top bar weather widget, all it needs is an API key and valid location
– https://www.screencast.com/t/bFgm2eaJua
– https://www.screencast.com/t/xt4PPreAjJBc
– https://www.screencast.com/t/LeS3k5DarE
– https://www.screencast.com/t/Mkep1BrrHz
Result – https://www.screencast.com/t/n8q1g1ip
Try generating another API key and use that one, there should be no problem.
2. That would be the latest articles section with pagination. Remove it by selecting a different page template for the page
– https://www.screencast.com/t/61fVxgpxD
3. Some footer templates have predefined content, this cannot be removed, and your added content will be displayed below them. There are multiple footer templates to choose from including blank templates
– https://forum.tagdiv.com/footer-templates/
Also a few theme versions before a new option was introduced, in the footer you can now use a page
– https://www.screencast.com/t/kiGVKIY5HrcB
Let us know if you have further questions, we will try to help as best we can.
Thank you
Sorry to keep bothering you guys but i was wondering if there was any way to make the website full screen instead of boxed?
Hello Simi360,
Notice that the theme will be boxed if you will use a background image for your website. If you will remove it, the layout will be automatically switched to the normal design.
im sorry i dont understand
What Catalin was trying to say, is that if you have full width elements in the website (stretched rows in pages, full big grids, full width revolution sliders, post templates will full width elements etc) and you set a background color/image
– https://forum.tagdiv.com/background-introduction/
The result will be that the website will be boxed, there will be no full width elements displayed.
So as long as there is no background image or color, rows can be stretched
– https://www.screencast.com/t/tM9dWee1jX
Full big grids can be used
– https://demo.tagdiv.com/newspaper/full-big-grid-1/
Also header and footer sections can be stretched
– https://www.screencast.com/t/ed3M6XfOG
Let us know if you have more questions.
