Loading slow / Updating WordPress not possible / Category not showing right
First of all, great Newspaper theme! Thumbs up!
First:
The last time we have some loading problems http://voedingsdomein . It takes to long (plugins deleted). Can someone help / advice?
Second:
We cannot update wordpress to 4.4?
Third:
When we want to put a new blog post, you just see a picture and no text?
We use your newspaper theme now for some years and are very happy.
Plz help
Theme has nothing to do with updating WordPress. Best way to do that is manually via FTP. See WordPress.org on how to update WordPress.
New version of Newspaper out today addresses couple of issues with WP 4.4 (nothing to do with “updating” WP).
Can you explain the other questions too? @Chris?
– Website loading very slow? Do you have some advice?
– When I want to put a new recipe on the website as a post, the lay-out is just a picture without the text?
What is the latest newspaper version? 6.0?
Its really slow xD. You server hosting its getting problem whit smooth scroll. Go to theme panel + template settings + smooth scroll and turn off this function.
The latest versión its 6.6.2 and you are using 6.2 (June 22th, 2015) . I recommend you update to latest version, there are alredy so many fixes in latest version
You need to update your theme to the latest version as many improvements were made since 6.2 :
If you update to WP 4.4. then you need to update the theme as well as some fixes are necessary for their compatibility.
https://forum.tagdiv.com/how-to-update-the-theme-2/
You then need to update the visual composer plugin: https://forum.tagdiv.com/how-to-update-visual-composer-plugin/
And also the tagdiv social counter: https://forum.tagdiv.com/tagdiv-social-counter-tutorial/ as it was modified a bit due to facebook changes.
After all these are done, you can use this guide to improve loading times: https://forum.tagdiv.com/how-to-make-the-site-faster/
I hope this helps.
Thank you all! Will do everything and will be back with my feedback…
