Mobile load speed decreased after update
After the latest update, I could find that there’s an improvement of Pagespeed score for Desktop: 96% to 99%. Great job done!
But the mobile load speed decreased drastically… 98% to 60% .
Please help
You can use mobile theme, this plugin was made spacial for mobiles and the speed will increase , also you can try to optimize your website
Please read this topic:
-> https://forum.tagdiv.com/topic/low-score-for-mobile-in-google-pagespeed-insights/
Thanks for your reply but unfortunately it does not help. With the same settings & plugins the Mobile score was 98% earlier.
Is there any specific settings need to be maintained?
Regards
Our developers theme are working to improve the theme speed, and we hope that this problem will be solved.
Sorry for the inconvenience.
There are some guides here in the forum regarding speed optimization, you could read them and try what is suggested
– https://www.infophilic.com/get-almost-100-pagespeed-newspaper-theme/
– https://forum.tagdiv.com/topic/score-100100-pagespeed-with-newspaper-wordpress-theme/
– https://forum.tagdiv.com/topic/newspaper-theme-speedify-your-website/
– https://forum.tagdiv.com/topic/tutorial-chriss-custom-optimizations-for-functions-php-etc/
You can try some speed optimization if you want.
Thanks for the links… I’ll surely try implementing those.
Please post me a note once the developers corrected the issue.
I like this theme a lot as it is perfect from all aspects. Please maintain the quality.
I just spotted another issue… the format options (Pull Quote, Center Quote) are not showing in Post create/edit page. Can you please check.
Please be that if you have a style Quote set you need to remove the set one and after that set the new Quote.
in posts
https://www.screencast.com/t/ghoObHyu7i
https://www.screencast.com/t/YUkUvJc9P
https://www.screencast.com/t/LK4Rjs2YD
in pages with td composer
https://www.screencast.com/t/FuMPqyFCNdBH
https://www.screencast.com/t/wvMUwwjydJC
What I wanted to mean, the ‘Formats’ option is not showing on Post create/edit page.
Check the screenshot…
https://i.postimg.cc/W4ysG1BJ/Capture.png
I think you have some plugins that interfere with our theme:
https://www.screencast.com/t/8ejzOhf8ky
https://www.screencast.com/t/LFR3PPAik
https://www.screencast.com/t/tYNDWwwP97bM
Please deactivate all plugins, clear all cache, and try again.
I deleted all cache and disabled the plugins… the option still not showing.
Plugin changes done recently…
Replaced Yoast SEO plugin with Rank Math SEO
Replaced WP Fastest Cache plugin with WP Super Cache
Please send us an email at contact@tagdiv.com and provide admin login, as well as cPanel or FTP if possible. We will take a look. Include a link to this topic in the email.
Can I use “WordPress SEO Plugin – Rank Math” with this Newspaper theme?
Rank Math is a brand new FREE plugin from MyThemeShop, that promises to be а main competitor in the fight of the WordPress SEO plugins, a fight dominated by Yoast for years.
https://mythemeshop.com/yoast-alternative/
Hi Viju,
Please note that we do not test that plugin with our theme, and we can not say for sure if this will work or not with our theme, but if you want to test it please make first a full backup to your website, in this case if will be some problem or your website will be stop to work you’ll have a backup.
Please I am requesting the NewsPaper theme developers to test this plugin with their theme and add it to their list of compatible plugins
Unfortunately this is not our priority in this moment, sorry;
If you want to use that plugin, you can test it on localhost, doing this will see if is compatible or not with the theme and the plugins that are you using.
Sorry for the inconvenience!
