mobile menu and layout does not works properly
i encontered problems with my developing site nuovo.unioneinquilini.it for mobile version. While the home page seems to work fine, when i open a page or a single post it seems like mobile menu doesn’t open and some blocks doesn’t work fine (for example, the social sharing box which seems to be totally without css). I tried the way-1 to mobile version (simply a responsive version). The issue is present either by mobile (android) and with developing tools by chrome on windows.
thank you.
Hello @danieleprimavera !
Please note that if a page is made by Composer, than the content won’t be displayed on Mobile theme version. You should create the content with the Mobile Editor.
Make sure you select the mobile theme and amp for those single templates.
Documentation here:
https://forum.tagdiv.com/tagdiv-amp-plugin-tutorial/
https://forum.tagdiv.com/the-mobile-theme/ and
https://forum.tagdiv.com/mobile-theme-introduction/
ok, i found the problem: a conflict with AMP. I deactivated it and now the issue is resolved.
