mobile speed
Hi there,
I’d like to improve the speed of the navigation from mobile
here you have the analysis from Google Analysis https://snipboard.io/KPzaiC.jpg
Hello @alessandrogini1!
A good choice for the page speed, it could be the mobile layout which contain less elements because it can improve a bit your page speed.
Our developers are working a lot to improve the page speed in every update, so make sure you use the latest update(11.4).
Some factors which you need to take into account are:
External factors: server speed, if you are using CDN or not, the external resources loaded by your website like ads, fonts, tracking scripts like Facebook Pixel, Google Analytics, Twitter analytics, Hotjar and so on.
Internal factors: the number of elements on the page, image size, image formats, if you are using mobile optimized layouts, console errors, if you are using the Standard Pack plugin on not, if you are using PRO demo or a standard one.
https://forum.tagdiv.com/topic/optimize-script-to-improve-site-speed/
– https://forum.tagdiv.com/topic/a-few-tips-for-newspaper-x-speed-high-cpu-usage-issues/
– https://tagdiv.com/how-to-increase-page-loading-speed/
– https://forum.tagdiv.com/topic/score-100100-pagespeed-with-newspaper-wordpress-theme/
– https://www.infophilic.com/get-almost-100-pagespeed-newspaper-theme/
– https://developers.google.com/speed/docs/insights/v5/about
– https://www.youtube.com/watch?v=tnkVapqhIHc
Please check the tutorials from those platforms gt metrix and Google Pagespeed Insights and I’m sure you can increase the page speed.
Please note that page speed is not covered by the support team: https://forum.tagdiv.com/newspaper-theme-support/
Hi there,
thanks for the reply.
What do you mean by mobile layout? the plugin?
I mean layout or template you like the most. For example, you can choose from the 3 options which one is the best and which one contain less elements, in order to improve your page speed.
