Hey devs,
i’m obviously new to the newspaper theme. Just purchased a few days back and going back and forth with the mobile websites.
1. The mobile theme plugin renders the mobile version on the desktops, so had to deactivate it.
2. Made individual mobile elements. However, Mobile footer is not showing up in the footer section on smartphones, instead the desktop footer is overlapping.
3. I can’t see the create mobile header template in the tagdiv composer.
site is mustechie.com
please take a look.
regards
hitesh
In addition, i’ve set a global category template that isn’t filtering posts as per the category.
Am I missing something?
1. When you create mobile pages with TagDiv Composer with Mobile Theme plugin installed, your pages will be overwritten by the plugin.
The Mobile Theme is a performance optimized theme included in the Newspaper main theme and it loads only for mobile devices. It comes with its own templates for page, post, category, etc so your current templates from the desktop theme will get converted to the mobile theme layout. For more details, please take a look here: https://forum.tagdiv.com/the-mobile-theme/ and https://forum.tagdiv.com/mobile-theme-introduction/
Better deactivate the plugin and see the results.
2. and 3. Please provide more details, like screenshots. If you create mobile templates/mobile pages you need to convert the existent header/footer like this => https://www.screencast.com/t/HrjOBNayd
Also, please check this topic where I explained each mobile version -> https://forum.tagdiv.com/topic/mobile-version-not-working-properly-2/ and choose what mobile version you want.
4. For the category template, if you have set a posts loop then will display all posts in this category or you can use Flex Block 1 and set the filter to “Category -Current category” => https://i.imgur.com/7P99qx0.png
thanks Anamaria for the prompt reply.
I’ll apply your suggestions and get back if need be.
thanks again.
