The top grid that is displayed on the front page when the mobile theme plugin is active, will display posts from the Featured category. Please make sure that you have posts in that category
– https://forum.tagdiv.com/featured-posts-2/
– https://forum.tagdiv.com/the-mobile-theme/
Ad codes for the mobile theme have to be inserted in the mobile theme section of the theme panel in order to be displayed
– https://www.screencast.com/t/c7LOAUgiFyaC
The mobile theme is optional, if you want the same content from desktop to be displayed on mobile, you can simply deactivate the plugin.
Thanks for your answer now i get it for Mobile front page.
But for adsense high scrapper I ment for normal page. How to add one? Because when i add your “ad box” it only show me small cube on front page. How to make your ad box bigger so i can fit in Scrapper ad?
In the Ad box element you will have to choose from which section of the theme panel it will display the ad
– https://www.screencast.com/t/kuEB9ALx
The ad code has to be entered in the theme panel desired ad sections
– https://www.screencast.com/t/DQfDrQJEjLC
If you are using Adsense you have options to modify the ad size
– https://forum.tagdiv.com/ads-adsense-overview/
http://prntscr.com/fy5679 It’s this one. On front Page. No matte what i Do he ain’t getting long like large scrapper
There is no limitation for the Adsense ad from the theme. It will display as it is, or you can control the size from the theme panel manually.
If you are absolutely sure that your ad is not displaying properly, please provide a link to your website so we can inspect the issue.
It’s still not working. It’s a small add
http://www.bjj-world.com
The ad that you are using has this size from what I can see
– https://www.screencast.com/t/ClLIwfOB
And that is how it is displayed by the theme. I believe the ad code you are using is not of the size you need.
Maybe you need to create a different ad with the size you want
– https://support.google.com/adsense/answer/6002621?hl=en
– https://support.google.com/adsense/answer/6002575?hl=en
Create the ad with the size you want and then enter it in the theme panel section that you want, and is suited to display that particular ad size.
