Hello @jubau!
Enable this option: https://forum.tagdiv.com/ajax-view-count/
Make a test and deactivate ALL plugins except tagDiv ones, also if you are using a cache plugin, deactivate it, clear all cache and try again.
Hello @jubau!
You can use a caching plugin. But please make a test and check if there is a conflict because of the caching plugin. Please make sure that is set as in our guide https://forum.tagdiv.com/cloudflare-cdn/, you need to disable the Rocket Loader.
thank you for your response
my rocket loader was active i made the set up i will let you know the result soon
for now i have another question
my SEARCH is very slow to come up, what can i do to resolve it please
you can check to see : http://www.bgospel.com
thank you
Hello @jubau!
I’ve checked and it’s loading pretty fast.
Please note that page speed or optimization is not covered by the support team: https://forum.tagdiv.com/newspaper-theme-support/
Thank you for understanding!
thank you i was able to fix the search but,
i really need help to find solution for 7 days and 24/48 jours posts sorting
– DNS is correct as per your request.
– SSL is FULL
– my security firewall is Low
– not using the pro plan
– Add the configuration rules
-clean all cache
but i can have 7 days and 24/48 jours posts sorting display.
really need your help for this
thank you
Hello @jubau!
If you follow this guide: https://forum.tagdiv.com/7-days-post-sorting/, then it should work well. Make sure there is no plugin conflict, and please update the theme to the latest update.
hi
i follow everything you say and nothing works
and today i found another problem
i create a youtube playlist https://www.bgospel.com/playlist-2023-de-musiques-gospel/
and again nothing work
can you guys check this please ?
Hello @jubau!
We can take a look, see exactly the issue and let you know what you can do there. Please contact us via email at contact@tagdiv.com and provide the following:
– admin url and credentials
want to tahnk you for 24/48, its work now nut remember there is 2 other questions in the same email
but now
can you tell me how to unmute video
check the link here https://www.bgospel.com/palmyre-seraphin-se-sou-li-mwen-kampe-video/
when page open, video start but stay on MUTE,
how to unmute them?
thank you
