Hi, just started the website – http://www.thepublicenvoy.com
As you can see, the grid on the main page is not showing at the top under the header. I need that fixed.
Secondly, when you scroll down the page, I have set sections such as ‘Politics’ ‘UK’ etc. How do I set these to show items from a certain category?
Thanks,
Jordan
This topic was modified 11 years by
publicenvoy.
Hi Jordan
For the second issue try this tutorial
https://forum.tagdiv.com/block-settings-tutorial/
Pat
I’ve been using demo blocks. I can’t figure out how to edit them on grid elements. Where exactly do I go? I’ve read through the tutorial but it doesn’t seem to answer it
I did not realise you could use visual composer on individual pages. Doy! My bad, I should be able to fix it now. Thanks!
How do I edit what appears on the post page at the side using visual composer?
Hello publicenvoy,
You can use visual composer on posts as well: http://screencast.com/t/hwKF5MsSH9, but this feature is not tested.
You can create your own sidebar to display then add widgets to it from appearance->widgets.
http://screencast.com/t/SdKZIMOUDe
You can read more in our documentation about it: https://forum.tagdiv.com/sidebars-tutorial/
I hope helps.
Hi, I was wondering how I update the theme, I noticed there was one available. And what changes will this cause to my setup?
Hello publicenvoy,
Our documentation covers that along with tons of other useful information regarding our theme:
https://forum.tagdiv.com/how-to-update-the-theme-2/
