I created a post directly on a page. Say Home>>Page (Post is in the page directly).
However, this displays as expected on the web view and on mobile view on phones, it displays the sidebar content in stead of the post itself.
Help!
Hello Vlad,
Here is the page giving the issue.
https://buzorcareers.com/how-to-excel-in-unilag-post-graduate-entrance-exams/
If you open the on your desktop and minimize your desktop to mobile view, it formats well.
However, if you open the same link on a mobile phone either iOS or Android, the main page information are not displayed, instead it shows the sidebar articles.
You can reproduce this to see the issue.
Regards,
Hello !
The Mobile theme was specially designed for optimization on mobile devices. Unfortunately on mobile theme you cannot do much changes of design. If you want to have the same design as on desktop mode you can achieve that by simply disabling the mobile theme.
You will have to recreate your pages into the Mobile editor or completely disable the mobile theme. The mobile editor will not render shortcodes !
Also If you want to use a gallery please follow this: https://forum.tagdiv.com/gallery-2/
Hello Vlad,
You’re the best, awesome support.
One more thing, the page header is not displaying on the mobile even after disabling the mobile theme.
“How To Excel In Unilag Post Graduate Entrance Exams”
What templates settings do I need to implement here?
Kind Regards,
Ayo
Hello !
Your header looks fine on our side: https://www.screencast.com/t/rNYdrIyRKJf Should I look in another place ?
Hey,
Apologies for late reply.
The page has a write up with an H1 tag, I could not found it, if you look at the link you shared,, the write up heading is not there.
Regards,
Hello !
Do you mean this H1 code ? https://www.screencast.com/t/DTPf68jX
This can be removed / changed only using custom work which is not covered by the Newspaper theme support: https://forum.tagdiv.com/newspaper-theme-support/
