Problem footer, posts in EDITOR PICKS not appear, POPULAR POSTS cant be updated
Hí! I updated to Newspaper 9.6
There is a many problems in the footer.
The following happens:
Posts in EDITOR PICKS not appear
And the POPULAR POSTS and POPULAR CATEGORY parts cannot be updated.
Any idea where it can be fixed?
  • This topic was modified 7 years by Coyotl.
So you are using footer template 1, the one with the two predefined blocks and a categories block
– https://forum.tagdiv.com/footer-templates/
The editor picks block displays featured posts (posts from the featured category), so if you have posts in the featured category they should appear there.
What exactly do you mean that the other blocks cannot be updated?
I could take a look at it, post a link to the website and some more details if possible.
Hi Simion!
Its ok, is to clear in the manual “to set up the footer”.
I solved the problem.
Thanks a lot!
I’m a bit confused by footer template 1, Simion C. Would you be able to clarify how it works?
Are the “two predefined blocks and a categories block” fixed, and cannot be modified if I am using footer template 1?
If not, and I want to use, say, footer template 5 and define my own widgets, am I able to choose to use “Editor Picks” as a widget?
OK, maybe I’ve answered my own question, in that I tried what I suggested and used one of the TagDiv widgets to create an “Editor’s Picks” widget.
However, while this was somewhat successful, my Editor’s Widget (which displays three most recent featured posts) displays the first post’s image as exceedingly large, rather than a thumbnail like the other two. (Your “predefined” widget displays all three as thumbnails).
Is this because I used the wrong kind of TagDiv widget? (Are the 25 TagDiv widgets different from each other? The info page is a bit vague on this question). Or is the one I used misconfigured in some way?
Finally found a block previewer, so you don’t have to guess what’s different about each [tagdiv] block:
https://demo.tagdiv.com/newspaper/flex-block/
To learn more about footer templates please read this guide: https://forum.tagdiv.com/footer-templates/
Yes the blocks are all different. Why would they be the same? IF they were the same it would not make sense to have multiple versions of the same block. Please read the theme documentation and check this section to see the different block layouts: https://www.screencast.com/t/l41HAGg8
What should I check if I have posts under the “Featured” category, but the posts aren’t populating? I didn’t do any editing to the code, either.
https://ourconstantjourney.com
Please check our documentation for Featured posts -> https://forum.tagdiv.com/featured-posts-2/
