Problem installing tagDiv composer
Trying to install “tagDiv composer”. And get this message: The package could not be installed. PCLZIP_ERR_BAD_FORMAT (-10) : Unable to find End of Central Dir Record signature
What is the problem?
Please make sure that the theme install was done correctly
Install via WordPress -> https://forum.tagdiv.com/install-via-wordpress/
Install via FTP -> https://forum.tagdiv.com/install-via-ftp/
Also, please make sure you have added the limit also in your wp-config.php file, in config is WP_MEMORY_LIMIT not PHP Memory Limit (there is a typo, sorry) – https://forum.tagdiv.com/requirements-for-newspaper/
and please increase all requirements that are lower, and follow all steps; make sure that the theme is activated and you use an SSL plugin for HTTPS.
Also, if you have other plugins activate, please disable them and see if the problem persists.
