Problem loading menu
Hello.
When I change between different pages/categories of the menu, there is a small delay that during a second uncofigures the style.
– Step 1 (i.e. I am in the homepage): http://www.screencast.com/t/Kv7iAiJxP
– Step 2 (I click in the first element of the menu, “Personajes”. The problem occurs): http://www.screencast.com/t/GbR76E0B07
– Step 3 (The page loads 100% and it is shown properly): http://www.screencast.com/t/o4NFzQ0ox0M
How can I solve this?
This is the property of css code it is applied in cascade. So the default css is loaded first then it is applied the custom one(I refer here also to the Theme Panel options like menu background). To avoid this delay you will need to add your custom color for the menu in the stylesheet file.
Also you could try to improve your loading speed – https://forum.tagdiv.com/how-to-make-the-site-faster/ and use a cache plugin – https://forum.tagdiv.com/cache-plugin-install-and-configure/ it may help and this delay should not be so visible.
PageSpeed gives me the some “ToDo’s”:
– Optimize CSS Delivery. This is regarding Newspaper. I don’t know how to do it (/wp-content/themes/Newspaper/style.css?ver=7.3)
– Minify CSS. This is regarding Newspaper. I don’t know how to do ir (/wp-content/themes/Newspaper/style.css?ver=7.3)
Should I do anything?
You can try to minify the css with cludflare: https://forum.tagdiv.com/cloudflare-cdn/ and also use gtmetrix to test your site not just the google testing tool as google can sometimes be wrong.
