PROBLEM LOADING TEMPLATE ARTICLES
Dear All,
i have a problem on our website https://gazzettadimalta.com/2022/italia/juventus-in-crisi-nera-373-in-borsa/ (article example) on desktop everything works fine.
On the mobile it’s like doesn’t load the css of the template here the screenshot https://snipboard.io/ajEZbx.jpg
may you help us? We are getting mad.
Thank you
Hello @miccmalta !
AMP is loading there and it is broken. In order to disable this option “Exit mobile version”, you need to disable this setting: https://i.imgur.com/LxpDtB2.png
The AMP works better only with the Mobile Theme plugin. From my point of view, if you don’t use the Mobile Theme plugin, then there is no reason or benefit to AMP. Please read all about AMP here: https://forum.tagdiv.com/tagdiv-amp-plugin-tutorial/
It comes with its own templates/design for page, post, category, etc so your current templates from the desktop theme will get converted to the mobile theme layout. Documentation here:
https://forum.tagdiv.com/the-mobile-theme/
https://forum.tagdiv.com/mobile-theme-introduction/
Deactivate them and see the results!
