Problem with Infinite Loading for Single Posts and composer
I want to activate Infinite Loading for Single Posts. i have followed every step that is metioned here but because i am using a preset template and not a cloud one, the composer doesnt even appear so i can turn on the setting. i am forced to use a cloud template? what can i do?
Hello @fotislab !
Unfortunately, this setting is only for the cloud templates.
We recommend to use cloud/PRO templates in order to have the possibility to edit them with the TagDiv Composer which contains a lot of functions and features, please check our tutorial here: https://forum.tagdiv.com/tagdiv-composer-tutorial/
Documentation here:
https://forum.tagdiv.com/cloud-library-templates/
https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
https://forum.tagdiv.com/cloud-library-category-templates/
Check also our video tutorials here: https://www.youtube.com/c/tagdivThemes/videos
Hope that helps you!
