problem with TAGDIV COMPOSER and Display of my own items categories
I cannot modify my home page with TAGDIV COMPOSER once on the online site and How to Display in a block only the articles of the Some categories desired?
Please check if you have set a static page on your homepage, only this can be edit with tagDiv Composer, the latest articles/posts (blog) is not editable with tagDiv Composer.
Also the blocks and flex blocks can be filter from this section -> https://i.imgur.com/pj7W6J5.png
Updating failed. Error message: The response is not a valid JSON response. this the message which appears when I go to modify the page with TAGDIV COMPOSER therefore impossible to save modification !!!
  • This reply was modified 6 years by nkayilu.
Please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
When tagDiv Composer is not working -> https://forum.tagdiv.com/tagdiv-composer-not-working/
