Salut am o mare problema de la ultimul update sunt o mie de errori in primul rand detin codul adsense in pagina pentru a adauga reclamele automat reclamele nu mi se mai afiseaza sunt blocate habar nu am de ce . a doua problema imi blocheaza pluginul yoast inainte in source view-source:https://www.vdtonline.com/ aparea la linia 10 ca acest site este optimizat de yoast seo acum nu mai apare apare gol la punctul 10. e din cauta pluginului booster ? si la https://developers.google.com/speed/pagespeed/insights/?hl=ro&url=https%3A%2F%2Fwww.vdtonline.com%2F inainte imi aparea pe mobil si pe dextop 95 optimizat acum pe mobil apare 25 optimizat deci sunt prea multe errori de care eu nu am habar am cautat pe google am cautat aici pe forum nu stiu cum sa le repar, si sa instalez 1 milion de pluginuri in website nu vreau pentru a optimiza siteul. Va rog frumos trageti un ochi la domeniul http://www.vdtonline.com dar nu asa la repezeala trageti un ochi calumea si spuneti-mi va rog mai exact problemele. Multumesc frumos
This topic was modified 7 years by
Robert90.
I check your website and now the ads seems to appera https://www.screencast.com/t/sXdVYnLq if there are more problems with ads please provide some more details and some screenshots were the ads do not appear.
Please notice that the speed of your website depends on how well your site is optimized.
There are many optimization guides provided by our users here in the forum, some made by us, you could check some of them
– https://www.infophilic.com/get-almost-100-pagespeed-newspaper-theme/
– https://forum.tagdiv.com/topic/score-100100-pagespeed-with-newspaper-wordpress-theme/
– https://forum.tagdiv.com/topic/newspaper-theme-speedify-your-website/
– https://forum.tagdiv.com/topic/tutorial-chriss-custom-optimizations-for-functions-php-etc/
– https://forum.tagdiv.com/topic/theme-causing-high-cpu-usage-2/
– https://forum.tagdiv.com/topic/sql-querys-high-cpu/
– https://forum.tagdiv.com/topic/newspaper-theme-slow-to-respond/
– https://premium.wpmudev.org/blog/optimizing-your-wordpress-database-a-complete-guide/
– https://underconstructionpage.com/optimize-wordpress-database/
– https://crunchify.com/better-optimize-wordpress-database-all-in-one-guide/
Hope this will help you.
pana sa fac ultimul update cand intrai pe prima pagina pe dextop anunturile adsense se adaugau singure https://www.vdtonline.com/ in jur de 3-4 anunturi apare-au pe prima pagina. pe mobil auto adsense merge perfect pe dextop nu merg, ceva le blocheaza. si despre pluginul yoast am trimis ticket la ei si au verificat si ei si au spus sa vorbesc cu cei de unde am cumparat tema. Va dau un exemplu cum aparea inainte si cum apare acum. http://prntscr.com/m5rjxg asa aparea inainte (<!– This site is optimized with the Yoast SEO plugin v9.3 – https://yoast.com/wordpress/plugins/seo/ –>) si dupa ce am facut update acum apare asa http://prntscr.com/m5rkd4 la punctul 10 apare gol ceva blocheaza.
Please check this documentation for How to set up Auto ads and make sure that you set the code in header https://www.screencast.com/t/x8wa27Xfm
https://support.google.com/adsense/answer/7480616?hl=en
Also please check this documentation too -> https://forum.tagdiv.com/using-other-ads-non-adsense-ads/
About Yoast SEO I see that you deactivate this plugin.
Codul a fost mereu in header http://prntscr.com/m5ucid am si spus pana acum anunturile apare-au am facut update si nu mai apar, am crezut ca am facut update gresit ca un fisier nu sa incarcat corect sau ceva de genul am facut update din nou si la fel. deci pana acum nu am avut probleme deloc cu tema repet de la ultimul update am problemele acestea. generez o parola si un user sa verificati DVS ???
Despre seo nu este dezactivat din contra este premium pluginul seo este cumparat http://prntscr.com/m5udcw .
Yes, you can send us an email at contact@tagdiv.com and provide admin login, as well as cPanel or FTP if possible. We will take a look. Include a link to this topic in the email.
