Bonjour, environ une fois sur deux lorsque l’on va sur ActuMonde.fr, les images des articles ne s’affichent pas.
Par contre, lorsque l’on clique sur le logo pour retourner à l’accueil du site, les images ne s’affichent jamais.
Screenshot : http://actumonde.fr/wp-content/uploads/2017/02/2017-02-15_15h03_29.png
Merci d’avance, cordialement,
This could be a plugin conflict so please disable all plugins except visual composer, clear cache and reset cdn files if you use it. Please also check any custom code you might have added to the theme panel or the theme files. If you use a child theme, please switch to the main theme to make sure it does not affect the proper functionality of the theme.
I see you also use cloudflare so it could be a miss-configuration of the cache and cdn. Please only use wp super cache and these settings: https://forum.tagdiv.com/cache-plugin-install-and-configure/ and for cloudflare: https://forum.tagdiv.com/cloudflare-cdn/
I have checked your site but cannot see any missing images. They all seem to work every time. I tested and loaded it over 20 times but no error was shown. Please test from a different device as well. The mobile version also loads properly. You can try to disable the lazyload option as it is the first to break on a javascript error. That is the cause of disappearing images as it translates from an opacity of 0 to 1 and if a js error is presented, the image opacity is stuck at 0.
Disable lazyload to fix disappearing images but the js error will not get fixed. That is something you will need to investigate and see where it originates. I cannot see it right now.
It is still not showing up on our end. I already clocked on the logo and on categories and I did so again but still there was no issue.
If you are referring to these posts https://www.screencast.com/t/wKsl9TEip, that is NOT an error. You are seeing a theme placeholder image because those posts do not have a featured image set. Please add featured images for your posts so the theme can show a thumbnail instead of the placeholder: https://forum.tagdiv.com/featured-image-or-video/
