I friend who has a SEO agency just ran me a SEO check up and noticed that my articles/pages where quite “heavy in code”.
If Google recommend a 50 octets text/code size, mine is around 150-180.
What is your take on it ?
I though it might be the code of theme itself ?
How can i reduced this number to get as close as i can to 50 ?
It appears to be important for loading page speed.
My website is : https://www.downshift.fr/
Regards,
françois
I do not know for sure what you refering to hard to code, if is about the SEO, then you can use Yoast SEO -> https://yoast.com/wordpress/plugins/seo/
Also you can try to make one more test with a default WordPress theme.
Here is your actual speed now https://developers.google.com/speed/pagespeed/insights/?url=https%3A%2F%2Fwww.downshift.fr%2F&tab=desktop
Thanks for the respons but we are not talking about the same thing.
I get this message :
Link : https://ibb.co/vXftm89
François
Please check this articles about:
Are Text to HTML Ratios Important?
You can try to optimized your website performance, in this way the text/code size will decreases
– https://www.infophilic.com/get-almost-100-pagespeed-newspaper-theme/
– https://forum.tagdiv.com/topic/score-100100-pagespeed-with-newspaper-wordpress-theme/
– https://forum.tagdiv.com/topic/newspaper-theme-speedify-your-website/
– https://forum.tagdiv.com/topic/tutorial-chriss-custom-optimizations-for-functions-php-etc/
Hope this will help you.
