Simple Questions on CPT post display page
Hello. Some simple questions.
I made a new Custom Post Type (CPT) called “letters”
Temp
I have this page to show all the posts. I made the page using the Cloud Templates. I used “Duplicate” from an the existing Category template that I am using in my website, and then modified it as needed. See here:
https://arcata1.com/category/gateway-plan/community/letters-comments/
That is fine.
When I click on a post link, it takes me this (link here) to display the post:
Example: https://arcata1.com/letters/lee-dedini-april-25-2022/
Questions:
1: What is this “https://arcata1.com/letters/lee-dedini-april-25-2022/” page? That is, what is it called and where do I go to edit it?
It does not seem to be any of the Single Templates that are shown. (Shown for me are Smart List Templates 1, 3, 6, plus some others.
2: How were the CPT posts linked to this page? (https://arcata1.com/category/gateway-plan/community/letters-comments/)
It seems to have been done automatically — which is great.
But I want to have the CPT posts on another Category page too. I built the page, using the same techniques in creating a Category Template but the CPT posts are not displayed on it.
3: In the tutorials / on-line manual on Custom Post Types, it shows the TagDiv Cloud Template page as having a new “box” for CPT. My screen does not show that.
I am using “CPT UI” as a plug-in, as this is what you recommend on this Forum.
1. Yes, it seems that you use default templates, instead of the cloud templates. You need to assign a cloud template and use the CPT on them: https://forum.tagdiv.com/custom-post-type-support/
We recommend to use cloud/PRO templates in order to have the possibility to edit them with the TagDiv Composer which contains a lot of functions and features, please check our tutorial here: https://forum.tagdiv.com/tagdiv-composer-tutorial/
Documentation here:
– https://forum.tagdiv.com/cloud-library-templates/
– https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
– https://forum.tagdiv.com/cloud-library-category-templates/
2. You need to use custom taxonomies templates and not the simple categories templates.
Check the documentation provided above.
3. You have to update the theme to the latest update, in order to have access for the new features.
