Speed Booster – Css to footer
I followed this guide:
https://forum.tagdiv.com/how-to-make-the-site-faster/
In the part that asks to put a function in “functions.php” to get all the .css and .js files of WordPress, for me only a few, not all, appear.
I say this because, I need to change to the footer, the theme style.css and the style.css of the Demo. This is causing render lock.
Speed Booster is on.
Hello alecaus,
Check if the Speed Booster is enabled in System Status. It can be disabled if you are using some untested plugins which are not tested with it. Otherwise, please check the following topic from here -> https://forum.tagdiv.com/topic/security-and-backup-always-incompatible-with-speed-booster/
Please notice that the speed of your website depends on how well your site is optimized. Notice that is not a simple task and if you do not have any experience in this regard you will do not bring good results for the theme. Also, notice that we have a speed optimization tutorial but this is addressed only to advanced users. So, if you follow the steps which are presented in this tutorial here -> https://forum.tagdiv.com/how-to-make-the-site-faster/ you can increase the page speed loading and if you are not aware of the steps in this regard, please consider hiring a freelancer/developer to help you because the speed optimization services are not covered by our support policy, as you can read here -> https://forum.tagdiv.com/support-policy-2/ Check our documentation here -> https://forum.tagdiv.com/requirements-for-newspaper/ regarding on dedicated server to fit our requirements.
Unfortunately, our theme does not have such an option to minify the style.css file and we cannot recommend any plugins with this functionality because is not tested with our theme. For minifying this file, we are using CloudFlare for our demo and works fine. If you want to read other views from our users, please check this topic -> https://forum.tagdiv.com/topic/tip-how-to-easily-minify-your-css-without-breaking-your-site/
One of our top members here on the forum wrote his own optimization tutorial here:
https://forum.tagdiv.com/topic/tutorial-chriss-custom-optimizations-for-functions-php-etc/ and here -> https://www.infophilic.com/get-almost-100-pagespeed-newspaper-theme/
Basically, these are the theme requirements
