SPEED OPTIMIZATION
There is something serious issue about speed optimization of the theme. Speed score is too low in PageSpeed and GTmereix. Of course, we are using a good caching plugin. But problem is if we put single ad and a video in the sidebar, page speed decreases a lot. This should be improved.
The page speed of your website depends on how well your site is optimized, if you follow the steps which are presented in this tutorial here -> https://tagdiv.com/how-to-increase-page-loading-speed/ you’ll be able to increase the speed of your website.
Also you can check this similar topic for more solutions: -> https://forum.tagdiv.com/topic/optimize-script-to-improve-site-speed/ -> https://www.infophilic.com/get-almost-100-pagespeed-newspaper-theme/
– https://forum.tagdiv.com/topic/a-few-tips-for-newspaper-x-speed-high-cpu-usage-issues/
– https://tagdiv.com/how-to-increase-page-loading-speed/
Hope this will help you!
Hi, how did you make this big slide on the front page?
Which big slide?
Start with the Newspaper Theme
Access the premium features and create your awesome website. To start, easily Install and Activate the following tagDiv plugins with a single click.
tagDiv Composer
Failed
tagDiv Standard Pack
Failed
The link you followed has expired.
Please try again.
The tagDiv Standard Pack plugin requires the tagDiv Composer plugin!
  • This reply was modified 6 years by soham24.
Install premium plugins
tagDiv Composer
Failed
Cloud Templates
NOT WORKING
@Nagarig The big slide on the main page. I really liked it. How did you make it? Does it cause slow page load?
@faith-2 Can you send a screenshot or link? I don’t understand which slide you are saying.
Please do not replay multiple times in topic, will only delay the time until you get the answer, we answer in topics from oldest to newest.
@fatih-2
you can use tagDiv Composer and the Big Grid Flex elements or slide element or the revolution Slider.
How to install Revolution Slider v5 -> https://forum.tagdiv.com/how-to-install-revolution-slider-v5/
Import Revolution Sliders on demos -> https://forum.tagdiv.com/import-revolution-sliders-on-demos/
@soham24
please try to install/update the plugins one by one from here -> https://i.imgur.com/s7BJQEF.png
