Speed Optimization
I have read all documents and guides by you. But still, my site speed is very very slow. please help.
The page speed of your website depends on how well your site is optimized, if you follow the steps which are presented in this tutorial here -> https://tagdiv.com/how-to-increase-page-loading-speed/ you’ll be able to increase the speed of your website.
Also you can check this similar topic for more solutions: -> https://forum.tagdiv.com/topic/optimize-script-to-improve-site-speed/ -> https://www.infophilic.com/get-almost-100-pagespeed-newspaper-theme/
– https://forum.tagdiv.com/topic/a-few-tips-for-newspaper-x-speed-high-cpu-usage-issues/
– https://tagdiv.com/how-to-increase-page-loading-speed/
Please note that page speed is not covered by the support team: https://forum.tagdiv.com/newspaper-theme-support/
For page speed and other services you can contact our custom work team here: https://tagdiv.com/premium-customization-services/
Thank you for your understanding
UPDATE> I tried everything you provided. Please check the speed now. Any PRACTICAL/Direct suggestions are welcome.
As I can see, you have some external links that takes a longer time to be loaded then your website content, this is one factor that cause the low speed.
Also I have a suggestion that can improve the pages speed, but I’m not sure, you need to test it. Please disable the infinite loading, you’ll need to edit the single post template with tagDiv Composer and disable the infinite loading.
-> https://tagdiv.com/infinite-loading-for-single-posts/ from post -> https://i.imgur.com/yIf6fA3.jpg -> https://i.imgur.com/KeclHLS.jpg -> https://i.imgur.com/4jHIHFY.png
Ok. Let’s try. I like infinity loading so let’s make it load after 90% of page reading?
HI,
Yes, you can do that too, but for a better accuracy you can disable it an check the results and after that enable it after 90%.
I disabled it and saw some speed improvements. So now we have to check other factors. Please do a speed test and suggest it. 🙂
As I can see the big problem is from Contentful Paint, please check these
10 Proven Ways To Improve First Contentful Paint (FCP) in WordPress
So should I use WP ROCKET Cache plugin? Good with newspaper X?
As I know there are users that are using it, but we can not say how is work or provide support for it, this is an untested plugins and we do not know the right settings for it.
Please follow the documentation of WP Rocket: https://docs.wp-rocket.me/article/1266-optimize-css-delivery
Also you can check these topic:
-> https://forum.tagdiv.com/topic/score-100100-pagespeed-with-newspaper-wordpress-theme/page/4/
