Sticky post does not seem to work
Hello, I have a post which i want to stay sticky at the topo of the page. I have already mark it as sticky, but it does not seem to work.
What I have done is to change the date of the post to have it the first of them all.
https://www.santiagoapostolcabanyal.es/
IS there something I have missed? Or is it just that NEwspaper does not support this wordpress feature?
Thanks in advance,
Lucas
Hello Lucas!
In order to avoid misunderstandings, then please provide more information about what you need to achieve, screenshots or a video(with the post you need to make it sticky).
Ok, the post is this:
https://www.santiagoapostolcabanyal.es/blog/feliz-navidad-5/
I want it to be sticky without having to change the date of the post. Is this possible?
You can see a video explaining my situation and what I want on this link:
Thanks in advance,
Lucas
Hello Lucas!
On that block the sort order is Latest, that’s why it will take the new one there up. That option from WordPress is no more working with our theme.
A solution to keep that post every time the first one is to use cloud templates and then it is very simple: add a block into the page with the post’s ID in filter, limit:1. After this block, you can exclude the post from above. Check this guides: https://forum.tagdiv.com/flex-block-settings-guide/ ; https://forum.tagdiv.com/offset-feature/
For more customizations, we recommend to use cloud/PRO templates in order to have the possibility to edit them with the TagDiv Composer which contains a lot of functions and features, please check our tutorial here: https://forum.tagdiv.com/tagdiv-composer-tutorial/
Documentation here:
– https://forum.tagdiv.com/cloud-library-templates/
– https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
– https://forum.tagdiv.com/cloud-library-category-templates/
Check also our video tutorials here: https://www.youtube.com/c/tagdivThemes/videos
Ok, thanks for the response.
