Text With Title and Column Text not saving content
I can’t get the content to be saved using Text with Title, or Column Text on Page Editor with TDComposer
Hello @CRiTiCAL!
“Column text” and “text with title” elements have a button called “edit content” and if you click on that button, the WP Editor will open and you can add some text/code there. Close the WP Editor from X, save the changes from Composer and view the page to see the changes.
If you did these steps and you can’t see the content on the frontend, then this can be caused if something interfere there when the WP Editor saves the content you added and the process can not be completed. Please check the steps from here: https://forum.tagdiv.com/topic/unable-to-edit-text-with-title/ and also other possible issue as here: https://forum.tagdiv.com/topic/403-error-on-tagdiv-composer-when-trying-to-use-wp-editor-wpedito-php/
Please check your .htaccess file also: https://www.screencast.com/t/MJ78SDZr4Gl -> https://forum.tagdiv.com/general-options-may-interfere-newspaper-theme/
Hope that helps you!
Hi!
I made all the suggested changes, especially the modification of .htaccess (SubstituteMaxLineLenght 10M), but the same problem persists. The text we write is not saved
I detected an error with chrome develope tools, when it launches WPEditor.
https://snipboard.io/Bfs1YT.jpg
I don’t know what could be happening
Tanks for u time
Hi CRiTiCAL, the problem that you have it can be solve if you disable the rocket loader from the cdn, the Cloudflare need to be set like in our guide -> https://forum.tagdiv.com/cloudflare-cdn/
Please try this and let us know the results!
