Theme Panel Footer Options Not Coming Up
1) Any method to implement Marquee with our own text and links?
2) Our question was that we tried adding HTML to both, Column Text and Raw HTML. Both are available under elements. What’s the difference?
1. You can use this guide – https://www.w3schools.in/html/marquee-tag and set the code in raw html element (using tagDiv Composer), like this – https://i.imgur.com/uJK05De.png
2. The raw HTML is like you are using a file with html extension, you can use in it html, css and js, but this will not render shortcodes, if you please a shotcode it will be display as text, but using the column text or text with title, those wll read the shortcode and display the content of that shortcode, also provides you the possibility to create content using the classic editor.
We just found that HTML Marquee Tag has been deprecated. Any other solution for the same effect?
To achieve the same scrolling or bouncing effect, you can use CSS animations. Here’s a simple example that mimics the horizontal scroll of marquee – https://pastebin.com/ you can edit the css after your needs. The code should be set in raw html.
Hi Calin,
I think you wrongly pasted the incomplete link of pastebin.com.
Sorry, please check this link – https://pastebin.com/Wvgs0sGY
Thank you Calin. We will try it.
Viewing 7 posts - 101 through 107 (of 107 total)
