Theme Panel Footer Options Not Coming Up
We were watching the video on how to create a website from scratch, and if was being used in it. So, asked about:
Extra CSS
Extended Shortcodes
Could you provide a screenshot with those elements? Then, I can understand what you mean and help you efficiently.
So, we cannot have a page template designed and use it as a standard? We have to create and design each page separately.
We can only send we use it ourselves. We watched in the video link that you sent to us, that was under the Single Post Template section, I guess.
“So, we cannot have a page template designed and use it as a standard? We have to create and design each page separately.” Yes, exactly.
As a help, you can copy-paste the entire row from a page already designed into a blank page. You can also duplicate the page, change the name, and make the changes in the Composer.
Do you mean the Extra class field of each shortcode? You can specify a class there to write CSS code quickly. So you can easily refer to that shortcode directly.
Each shortcode has an option called “Extra class.” You can write a class, such as “modify_class,” and write some CSS code using this class, such as “.modify_class.”
About this https://app.screencast.com/OdB8JAtjmRiwH? This is the name of the shortcode type (extended shortcodes) that can be used on any other pages/templates.
Actually, in video its hardly visible what exactly is written, so, we misunderstood. It is Extra Class. We found it in the composer also at the bottom of element properties.
Is there any detailed reference for this?
Yes, I’ve already explained all two terms. Let me know about your issue with them so I can help you.
Is there any detailed reference for Extra Class? How to create and use it?
Thank you Bettina.
Is there any detailed reference with examples for creating and customizing:
Widgets
Sidebars
Monetization/Ads from Adsense, other networks, and sponsored ads
The widget reference that you have sent is a particular example. There could be many types of widget that can be created and used.
We want a detailed reference for widgets and not just a particular one at this moment.
Unfortunately, we do not have any extra documentation about that.
You can build a sidebar with the TagDiv Composer in the cloud templates. Steps:
1. Insert one new row (or delete an existing one).
2. Divide into two columns (2/3 + 1/3).
3. You can add whatever element/shortcode you want from the tagdiv Composer to the second column and consider it a sidebar (also you can add an external shortcode with the help of the column text or text with title shortcodes from the tagdiv Composer)
The “Column text” and “text with title” elements have a button called “edit content.” If you click that button, the WP Editor will open, and you can add text/code/shortcode there. Close the WP Editor from X, save the changes from Composer, and view the page to see the changes.
There is
In the demo video for designing from scratch, at the 2:00:05 timestamp, there is thin line use to check alignment of the elements. Where is that option and how to use it?
How do we send the screenshot for your reference?
That one is used for the image of the article. It’s the vertical alignment of the image: https://app.screencast.com/PXemqlsUxFFCO
You got it wrong. The four arrows that we have used to point to the crosshair used to view the alignment of elements. Plz open https://app.screencast.com/eHQwij1elvdVt
Click there to see which element is displayed on the left side.
1) Plz have a look at https://app.screencast.com/vL2nLtOlrylkF
It is showing Zone.
Now, there is not option to choose element.
From where did this crosshair line come? It’s not clear from the video.
2) With Pages there is a option to Edit with tag Composer. But with Posts, there is no option to Edit with tag Composer?
3) Featured Image is not been shown on the top of posts and pages?
1. That is a guidance line that you’ve selected there. This line won’t be on the front end.
2. You can edit only the cloud templates with the tagdiv Composer. Please check the differences between cloud vs default templates from our guides:
– https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
– https://forum.tagdiv.com/design-post-pages-using-default-templates/
3. You can set a featured image only for posts: https://forum.tagdiv.com/featured-image-or-video/
1) We have not selected the guidance line. It is showing in the demo video. How to use guidance line? Where it is located?
2) There is a option for Featured Image when we edit pages also. But it does not show it anywhere.
Can we edit the Featured Image from composer also? We couldn’t find any such option.
1. You should not select that line. It’s by default from Composer.
2. Yes, because we do not have any shortcode to display the pages’ featured image, it means we do not support it. This is available only for posts and not pages.
The guidance line is still not clear. In the demo video it was not showing by default. The presenter activated it, used it, and then it was not visible.
How was it activated? I’m not sure I understand you correctly.
Can you please provide more information about it?
Viewing 25 posts - 51 through 75 (of 107 total)
