Theme Panel Footer Options Not Coming Up
In the demo video for designing from scratch, at the 2:00:05 timestamp, the guidance line is used. Plz check.
It seems to be clicking on that space between the elements and checking the zone, so there is nothing major.
We tried but we could not find the guidance line. It’s not major but can help in aligning elements. Plz advice.
There is no option to activate/deactivate something like this.
1) Do you have any good reference on using Inner Row and Inner Column?
2) Can we have multiple sidebars? Like one on left and second on right. Or two sidebars on right side?
3) There are settings under Theme Panel -> Template Settings -> Blog and Posts Template / Page Template, how can we use them? There is no option for multiple sidebars or one or left and second on right?
4) There is a option to create a sidebar under Theme Panel -> Template Settings -> Blog and Posts Template / Page Template. But how do we manage this newly created sidebar?
1. Unfortunately, no. An inner row is a row within another row that has columns called inner columns because they are part of the inner row. You can add an inner row only into another row or column. They also have settings as any other shortcode/element from the tagdiv Composer. How to remove an inner row? The easiest solution is to click on the inner row word: https://app.screencast.com/PNI0Lolb0ZTm2 press Delete from your Keyboard, and click YES: https://app.screencast.com/sLv2xfmsO812v
You can set a row/inner row to be sticky or not from its settings: https://app.screencast.com/meYQjYKITuGuR .
You can reduce the inner columns of your inner row like this: https://app.screencast.com/bwmRwvQpsT2of
Please take a look here in this video for example where I build 6 columns: https://www.screencast.com/t/mZ2c5XamTFN2
2. Yes, with the help of the tagdiv Composer. Add a row and split it into 3 columns: https://prnt.sc/-y3xWBjrjmPD.
You can also specify the width of your columns, like 20%,60%,20%: https://prnt.sc/2zjfi6c2phgN
Drag and drop every element in each column. Example: https://prnt.sc/T2YSJ-cU73Eh
There are some settings to align it in the tagdiv Composer, click on the element: https://prnt.sc/lcYDthjDhhzv
3. No. These settings from point 2 are found only in the tagdiv Composer and you have to use a cloud single post template. The theme panel settings are proper for the default templates(those can not be edited with the tagdiv Composer).
Please check the differences between cloud vs default templates from our guides:
– https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
– https://forum.tagdiv.com/design-post-pages-using-default-templates/
4. Already explained at point 3.
For #3, so, if we are using the Single Post Blank Template, then we need not change any setting in Theme Panel for sidebar as it is for the default templates i.e. the Standard Pack?
The video link “https://www.screencast.com/t/mZ2c5XamTFN2” that you shared is not working. It opens the “https://app.screencast.com/” link but no video is visible.
Yes. You should make the changes in the tagdiv Composer. Here is the useful video where are the 6 columns on one line: https://app.screencast.com/P0x3Gn6gEyHlC
Hi Bettina,
1) How can we have multiple authors in a post?
2) How can we add ads in post content?
3) What’s the Lock Modified Date?
4) How can we add the reading time for the blog post or page?
5) How can we add Editors and Reviewed by to a blog post or page?
6) How to customize Ordered / Unordered List with arrow or a custom bullet?
7) Where the option for Box Quote?
8) How to get the marked tabs in the screenshot here: https://app.screencast.com/DsEp8ylHDPWcO
Hi Cloud Hosting,
1. The theme do not provide this option, therefore you’ll need to use an extra plugin to achieve multiple authors in a post, I hope our guide will help you – https://forum.tagdiv.com/adding-multiple-authors-articles/
2. Those can be added using the guide for ads inside post content – https://forum.tagdiv.com/article-ads/
3. If you are referring to the format, this can be set custom as you like – https://i.imgur.com/xOjndDn.jpeg
4. Use tagDiv Composer on single post element and add the reading element on the template – https://i.imgur.com/b6i9REe.jpeg – https://i.imgur.com/6dsjZ5L.jpeg
5. I believe this is best done directly in the post content at the end of start of the article, therefore will no need for extra options.
6. I believe this is related to an article list that can be done using the wordpress editor – https://www.google.com/search?q=lists+style+goutenberg+wordpress#fpstate=ive&vld=cid:c16f3c84,vid:AR4c3BhZr1M,st:0
7. There are a few options in the classic editor and a few in Gutenberg editor that can be used – https://wordpress.com/support/wordpress-editor/blocks/quote-block/
8. This is an option that can be set on theme blocks, for this you need to edit the page or the template using tagDiv Composer – select the block and check in filter tab the settings for ajax categories dropdown – https://i.imgur.com/k79i7H3.jpeg the results will be – https://i.imgur.com/aoOEyBa.jpeg
1) For #3, What’s the Lock Modified Date, means, what exactly would Lock Modified Date do?
2) For #5, How can we add Editors and Reviewed by to a blog post or page, means, how can we add Editors Name and Reviewed by Name in the blog post, just as the Author Name is displayed. A post can have a Author, Editor, and a Reviewer also. Is it possible to add any two or all three of these along with Author Name in the blog post?
3) For #8, I guess the option that you have mentioned is to Filter only. We want the tabs like it is shown in the screenshot shared at https://app.screencast.com/DsEp8ylHDPWcO:
“All, Fashion, Street Fashion, New Look, Vogue, More”, The More drop down shows more Categories/Options.
1) For #3, Can you please let me know where did you saw that option? Also a screenshot can help (this is because it is possible to be a custom filed set with a plugin).
2) For #5, The theme has only the option to display the Author name, to add other 2 you can use the ACF plugin and and you can create 2 custom fields, one for Editors and one for Reviewer and display them on posts, then to display the on articles you can edit the single post template with tagDiv Composer and add the custom filed element where you want to have those elements and choose the source for them – https://i.imgur.com/mmSa6dm.jpeg – https://i.imgur.com/7KICfDS.jpeg – https://i.imgur.com/AvLTWZ5.png
3) For #8, please try as I mentioned above. Using that option will bring the categories you have like in the shown image.
Please find the screenshot for Lock Modified Date at https://app.screencast.com/lF8O8pQ4AFUAY
Thank you for the images.
That option is not from the theme or WordPress (fresh WordPress with newspaper theme doesn’t have that option – https://i.imgur.com/2ujjiKB.png) it is from an extra plugin that you are using.
Thank you Calin.
It’s a plugin option. Just found it.
Can we show custom text and link them to a URL, just like text links or HTML Marquee Tag? We couldn’t find any option in the News Ticker. Any solution?
Any element through which we can implement HTML code for customer text links or affiliate links?
How can we implement “FAQ Schema markup (JSON-LD)” in blog posts in Newspaper theme? This query is for both, FAQs at the bottom of blog posts and a dedicated page or post for FAQs.
If you want to add html code in a page or template you can do it using the tagDiv Composer and raw html element – https://i.imgur.com/ZVVYZSt.png
For FAQ you can use a plugin or html code, if you like you can import from cloud in a page or template a pre-made FAQ – https://i.imgur.com/OTbRuNO.png – then just adjust the text and html code (this is not so easy as using a plugin).
To implement “FAQ Schema markup (JSON-LD)” you need a seo plugin:
How to add FAQ Schema in WordPress using Yoast SEO
Is there any element that works like HTML Marquee tag? News Ticket works on only categories. Any alternate solution?
What’s the difference between Raw HTML and Column Text? Both can take HTML code. Any reference you have?
Is there any element that works like HTML Marquee tag? News Ticket works on only categories. Any alternate solution? unfortunately the only element that is similar is the News Ticket element.
The Raw HTML allow you use html code with css and js (it will be similar with a html file, it’s usually used for html code, js code and css code that should be used on that page or template, the css code should be set between css tags and the same should be the js code), the Column Text is using the classic editor and is used for adding text, images …. and use the provided elements to still it.
Viewing 25 posts - 76 through 100 (of 107 total)
